86z or iroc
Old 01-03-2004 | 11:40 PM
92RS87Z_Driver's Avatar
Car: 92RS
Engine: 305tbi
86z or iroc
I just bought a 86 camaro. It originally came with a carbed 305 but now has a 350. But anyways, it has Iroc suspension and wheels and the 145 speedo. Im not sure if it is a iroc or not. Its that dark maroon color. Ive never seen a z28 painted that color or come with a 145 speedo. I still need to run the rpos, but whose to say that the glovebox lid is original? I was wondering if someone could maybe shed some light on the situation. Thanks
Old 01-04-2004 | 12:15 AM
ray royer's Avatar
IS IT A AUTOMATIC OR STICK CAR. IF THE ORIGINAL MOTOR IS A CARBED 305 AND ITS A AUTOMATIC ITS PROBABLY NOT A IROC. THE ONLY CARBED IROC'S WERE 5 SPEEDS . DOES IT HAVE A IROC DASH PLAQUE. WELL HOPES THIS HELPS.
Old 01-04-2004 | 03:06 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Well Zs (non 91-92) were two toned, IROCs were one color.
Kevin
Old 01-04-2004 | 07:23 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
B4C
Old 01-04-2004 | 07:24 AM
oh yeah, the RPO sticker will have the VIN on it
if the VIN matches and you have code B4C you have an IROC
Old 01-04-2004 | 07:51 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Oh boy.... so far, almost every bit of information is incorrect. Let me set this straight for the record.
Not correct. The no-cost base Z28 engine in 1986 was the 305 carb (LG4) and there were no transmission restrictions with this engine. The 5-speed was the no-cost base and the auto was an option. I, in fact, owned a 1987 IROC-Z convertible once. It came equipped with a 305 carb (LG4) and auto and have the original window sticker to prove it.
True, but who's to say whether the car has been partially or completely repainted... As old as these cars are today, you cannot make this assumption.
B4C
That would be B4Z. B4C (police package) was not used in the '80s on Camaros. B4Z is the optional IROC-Z package in 1985 thru 1987.
oh yeah, the RPO sticker will have the VIN on it. If the VIN matches and you have code B4C you have an IROC
Correct, except replace B4C with B4Z.
Now, let me address your orignal statements:
How do you know what suspension you have? You cannot visually tell the difference, except for the inclusion of the Wonderbar on IROC-Z's.
It's also possible that you have a Z28 without the IROC-Z option. Late 1986 Z28's (with and without the IROC-Z option) were equipped with a 145-mph speedo.
Look for the tire sticker in the driver's door jamb. It will list the original tire size and load ratings. If it lists a 16-inch tire, you've got an IROC-Z. If it's a 15-incher, it's a Z28.
Again, we cannot use this information to authenticate.
As before, the SPID sticker also lists the VIN. Match it and you'll know it's original.
Old 01-04-2004 | 10:16 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
Originally posted by 1991tealRSt-topGuy
B4C
isnt that the police car option?
i thought IROCs (85-87) were RPO B4Z and IROCs(88-90) were Z28?
edit: should have read Willie's post first
Old 01-04-2004 | 03:26 PM
my bad
i thought something was wrong with what i said
< me
thank you for correcting me Willie, i hate misinformation just as much as the next guy
Old 01-05-2004 | 02:39 AM
Engine: L98 350 TPI
Well in all seriousness I am asumming it is stock paint, I mean if we are assuming other wise it could be all not stock, and turn out to be a SC or something. I am just informing him on the fact that two tones are Z28s and IROC-Zs are one color.
Kevin
Old 01-12-2004 | 01:44 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
all you can do is run the vin and as said before B4Z is what your looking for and match up vin's on the console
Old 01-12-2004 | 07:37 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Would this also hold true for a 87?
Old 01-12-2004 | 08:14 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Yes. There were no Z28's with the 16" rim as standard and all 87 IROC-Zs came with 16". It was 88 that changed that standard.
BAMiller
09-14-2015 06:38 PM
angel2794
09-08-2015 06:22 PM
FLAP
Camaros Wanted
09-02-2015 09:22 AM
g.l.mos
08-22-2015 12:02 AM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: 86z or iroc
