Help with RPO codes
Old 10-30-2003 | 09:25 PM
Robyn's Avatar
Help with RPO codes
I ran the RPO codes from my build sheet and do not understand some of them. Could someone help shed some light on what these codes mean:
22B : TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (B)
22I : INTERIOR TRIM, DK STEEL BLUE (91)
(which one is seat color, panels, headliner as I am color blind and cannot tell a color difference).
B23 : ORNAMENTATION, EXTR WHEEL OPG SPOILER
(possibly the small early style ground effects on 82-83 Trans Am's)
T93 : LAMP, TAIL & STOP, SPECIAL
(Mine look like every other 83 Firebird I have seen wether it be stripper or loaded)
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
The car is an 83 Trans Am. Also there are several codes listed that are not found in the database, is there a place to submit what is on the build sheet so these codes may be added later?
Here a couple of pics of the car
<img src=http://images3.fotki.com/v25/photos/1/17972/167850/left34-vi.jpg>
<img src=http://images3.fotki.com/v25/photos/1/17972/167850/leftrear34-vi.jpg>
I appreciate your help and know I will be asking more questions as the restification of my car gets under way in earnest this weekend.
Robyn
Old 10-30-2003 | 10:21 PM
82RECAROTA's Avatar
Old 10-31-2003 | 08:11 PM
Robyn's Avatar
Here is a list of my other codes, I tried to PM them to you but it said it was too long and when I shortened it, I am still not sure it went thru.
15L : SECONDARY COLOR, EXTERIOR, ASTRAL SILVER (91)
A31 : WINDOW, POWER OPERATED, SIDE
AK1 : RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR,
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
D35 : MIRROR, OUTSIDE REAR VIEW
D80 : SPOILER, RR END PNL
GU5 : AXLE REAR, 3.23 RATIO
J50 : BRAKE SYSTEM, POWER
K19 : REACTOR SYSTEM, AIR INJECTION
K64 : GENERATOR, 78 AMP
LG4 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
N10 : EXHAUST SYSTEM DUAL
N33 : STEERING COLUMN, TILT TYPE
N89 : WHEEL, TURBO ALUMINUM
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NB1 : EMISSION SYSTEM, CLOSED LOOP
TR9 : LAMP, GROUP
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U23 : CLUSTER, INST, TRIM ODOM
U29 : LAMP, INTR I/P, COURTESY
U75 : ANTENNA, POWER, RADIO
UD6 : ALARM, EXHAUST TEMP
UN9 : RADIO, SUPPRESSION EQUIPMENT
Unable to locate code 19M in our database! On build sheet listed as Black Accent
Unable to locate code 2DR in our database! On build sheet listed as T/A Model
Unable to locate code AO1 in our database! On build sheet listed as Tinted Glass
Unable to locate code BU8 in our database! On build sheet listed as Delx Dr Handl
Unable to locate code MX0 in our database! On build sheet listed as 4 Spd Auto Tr
Unable to locate code NO9 in our database! On build sheet listed as Fuel Filted L
Unable to locate code QYC in our database! On build shee listed as P205/70R-14W/
UT1 : TONE GENERATOR, WARNING
UU7 : RADIO, AM/FM STEREO, CASS, CLOCK ETR
VK3 : LICENSE PLATE, FRT MOUNTING PKG
WS4 : MODEL CONVERSION, TRANS AM
I appreciate your help,
Robyn
Old 10-31-2003 | 10:04 PM
82RECAROTA's Avatar
89-IROCZ-5.0TPI
02-22-2022 09:26 PM
Falcon50
08-22-2020 03:26 PM
racereese
10-03-2015 03:46 PM
Luigytico09
10-01-2015 08:46 AM
dusterbd
09-29-2015 08:40 AM
Quick Reply: Help with RPO codes
