hmm is this rare???
Car: 1987 Z28 Camaro
Engine: 305 tpi
hmm is this rare???
ok well i brought this up before asking if this was rare or just a add on, all of you mainly said a add on, my dealer said its rare, well i just checked al the rpo codes and one was D88 : DECAL, STRIPE, SPORT
1PV : PAINT SCHEME, 21
so they had to make it, so im confused, is it rare, anyone know? what do you think this means?
Engine: 305 tpi
also here is complete list of codes
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
Unable to locate code 84A in our database!
B91 : ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
E5Z : SPEEDOMETER ADAPTER (DELETE)
NP5 : STEERING WHEEL, LEATHER WRAPPED
U25 : LAMP, INTR, RR COMPT, COURTESY
1AY : 1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
9NM : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
B94 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR I
Unable to locate code E7Z in our database!
N33 : STEERING COLUMN, TILT TYPE
U26 : LAMP, INTR, ENG COMPT, COURTESY
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
D08 : PAINT, HIGH GLOSS FINISH
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
TR9 : LAMP, GROUP
V73 : ANTENNA, FIXED
6ZX : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
B18 : ORNAMENTATION, INTR, DELUX
D34 : MIRROR, VISOR VANITY
K68 : GENERATOR,105 AMP
T93 : LAMP, TAIL & STOP, SPECIAL
YR1 : SEAT,FRT CUSTOM
7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
B3W : Advanced Price Sheet Processing Option
D35 : MIRROR, OUTSIDE REAR VIEW
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
UA1 : BATTERY, HEAVY DUTY
YS1 : SEAT,RR CUST
8NM : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
D6D : GEAR, SPEEDO DRIVEN
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
UQ1 : RADIO PROVISIONS, FOR STEREO
YT1 : BUILD UP DR & QTR
81Q : MOLDING COLOR, BRIGHT RED (91)
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
D80 : SPOILER, RR END PNL
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
UX1 : RADIO, AM/FM STEREO CASSETTE EQUALIZER
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
81U : PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
AM9 : SEAT, RR, SPLIT, BACK, FLDG
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
E9Z : SPEEDOMETER KEY (DELETE)
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
U29 : LAMP, INTR I/P, COURTESY
1SB : OPTION PACKAGE 02
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
F41 : SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
U75 : ANTENNA, POWER, RADIO
16P : WHEEL COLOR, BRT WHITE (91)
19C : TRIM COMBINATION, CLOTH, BLACK (C) (91)
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
PB4 : LOCK CONTROL, WHEEL
GU2 : AXLE REAR, 2.73 RATIO
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
AU3 : LOCK CONTROL, SIDE DR, ELEC
A01 : WINDOW, TINTED, ALL SHADED, W/S
C49 : DEFOGGER, RR WINDOW, ELECTRIC
G80 : AXLE POSITRACTION, LIMITED SLIP
P20 : HUBCAPS, WHEEL, STYLED
VAN : ASSEMBLY PLANT, VAN NUYS, CA
19I : INTERIOR TRIM, BLACK (I) (91)
A31 : WINDOW, POWER OPERATED, SIDE
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
J50 : BRAKE SYSTEM, POWER
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
VK3 : LICENSE PLATE, FRT MOUNTING PKG
199 : SEAT BELT COLOR, BLACK (91)
TR9 : LAMP, GROUP
YS1 : SEAT,RR CUST
Car: 1987 Z28 Convertible
Transmission: 5-speed
RPO D88 refers to the original striping found on 1987 Z28's, with and without the IROC-Z option. I'm not exactly sure what 1PV is, but I know this code is on every 1987 Z28 (without IROC-Z option) I've owned.
I hope you're not asking whether your paint is original because your 1987 Z28 never looked like that when it was new. Depending on exterior color, the ground effects and wheels were either silver, gold or charcoal, accented with a four-color stripe just above the rocker panels. No other striping (including pinstriping) was available.
Engine: 305 tpi
hmm.. well i know my paint is not original, but its been painted over the original, that is why its not too good of a paint job, but u can tell the stripe was there original because of peelin and its rough from the old paint,
Engine: 305 tpi
this package had to come on some camaros because its painted on, not just a sticket, and it was bought like this from the dealer, previous owner has pic right out of dealer, i will post that later on
yea i relize that, im sayin my stripe is painted?
I can't tell from a pic. Take it to any body shop and they'll be able to tell you.
i just hope my dealer isnt blowing
I have found that the worst place to go for information on originality is a dealership. They don't care about this topic and it's not very often you'll find someone who works there that was there 15-20 years ago, much less know about one car line.
Willie
Willie
Engine: 305 tpi
woops sorry, i mean i know its not a sticker, idk why i put the ? marks, lol, yea i have one side almost sanded down cause im bout to get a new paint job, i just want to know if it is rare or not before i paint it, cause if it is, its goin to orinal colors, the z28 stlye, if no its goin to viper red,
No, an '87 Z28 coupe is not rare in itself. Even if it were, you will not be able to find original striping for it. It is the only year that no one reproduces the Z28 stripes... at least not yet.
Willie
Willie
sjorgens
10-01-2015 07:54 PM
