how can i tell if my car is a real formula ?
Old 09-28-2003 | 03:20 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i just did the vin decoder on the site and it said nothing about whether or not it was a true formula, when i bought it i was told it was, but i want to make sure, it has the hood, the stickers, ws6 but i have no orginal paper work or owners manual for the car.
it says formula on the title, and registration, but i was looking at the faq's page and it said that formula's in 91 did not come with the lo8 engine, and that is what mine has.
the vin is 1G2FS23E7ML****** if that helps any ?
Old 09-28-2003 | 09:16 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i've seen many formula's with the LO3
Old 09-28-2003 | 09:26 PM
jase's Avatar
The ws6 makes it a formula.You should also have 16 ' wheels.
Guest
Guest
Posts: n/a
Well, if it has the WS6 and no gfx, it has to be a Formula. Is WS6 on the SPID label (the one will all the RPO's) or just the parts on the car and you think it has WS6?
Old 09-28-2003 | 09:33 PM
Car: 91 formula
Transmission: t5
it has the 16" formula wheels and no gfx, but are the rpo's the numbers inside the storage compartment in the back of hte hatch ?
is the ws6 and wheels all that makes a formula a formula ?
Old 09-28-2003 | 10:30 PM
MdFormula350's Avatar
thats the highlights of formula's. the ws6 suspension, rims and no ground effects.
i was looking on the tech data page and in 91 the engines in the formula's were either 305 tpi or 350 tpi.
someone may have swapped the engine.
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Old 09-29-2003 | 05:11 AM
i should be more specific and say i have seen many 1991-1992 formies with the LO3
Old 09-29-2003 | 01:34 PM
Guest
Guest
Posts: n/a
Yea, thats probably where the list is on your car. Could be in the center console, but I doubt it.
As for the wheels, its a bad thing to use as a judgement call... those are so easily swapped. Really the WS6 parts arent too hard to swap on either, you need to find the RPO "WS6" on the list in the storage compartment. Then you know its a Formula, you couldn't get a Formula without the WS6.
Old 09-29-2003 | 02:06 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
WHAT MAKES A 87-92 FORMULA???
MUST HAVE ALL THE FOLLOWING (unless changed by owner)
- Power Buldge Hood
- Aero "wrap around" Spoiler
- NO GROUND FX EVER!!!
- Any F-body V8 offered that year. NO V6's EVER!!!
- WS6 Suspension
- 16" Wheels
- Gage Package
BTY, I used ot own a legit 91 Formula with the LO3/Auto combo.
hope that helps, for more info goto http://www.3rdgenformula.com
John
Old 09-29-2003 | 06:19 PM
Steve86TA's Avatar
Car: To many to list
many 91's came with the LO3 motor.
Old 09-29-2003 | 06:21 PM
Car: 91 formula
Transmission: t5
thank you okfoz i guess it is a formula and i do believe it is the origonal engine
Old 09-30-2003 | 06:26 PM
lb9mm5's Avatar
Car: 89 Formula
Engine: LB9
THe LO3 is Rancid, rip it out and go with the L98
Old 09-30-2003 | 08:39 PM
Car: 91 formula
Transmission: t5
sorry lb9 dont have the money for that right now, but after college if i still have the car i wouldnt' mind putting in a l98 with a six speed
Old 10-01-2003 | 07:25 AM
okfoz's Avatar
From what I have learned 6 speeds are VERY expensive, and saught after thus why they cost so much... You might be better off finding an LT1 connected to a 6 speed for your swap. A little less work than an LS1 conversion, but more expensive than a L98 conversion. BUT you can actually compete with 4th gens.
thats my next move
John
Jorlain
08-24-2022 05:11 PM
Scorched1984
Wheels and Tires
66
04-16-2016 06:56 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
Reborn756
09-04-2015 03:42 AM
reiderz iroc
08-13-2015 04:57 PM
Quick Reply: how can i tell if my car is a real formula ?
