Found my build sheet!
Car: 1984 Firebird S/E
Engine: 350 V8, 4 barrel carb
Transmission: 700 R4 automatic overdrive
Ok, it doesn't take much to excite me, but in redoing my interior, I found the build sheet for my car! It was kind of exciting to suddenly find the sheet the went down the assembly line with this machine and see some of the RPO codes decoded on it.
The weird thing is that I found it while ripping out the old original carpet! It was tacked to the floor with a piece of masking tape on the driver's side under the driver's seat with the carpet laid over the top of it.
Is this a "normal" place to find these things? Sounds a bit weird to me, but I'm happy to have it. Just another little piece of car history to go into my car's folder.
Brad
Brad
1 Post
Car: 1984 Trans Am
Engine: GMPP 350 V8
That is great news. I found my buildsheet in the bottom of my trunk under the carpet. Unfortunetly due to leaky weather stripping around the hatch it was totally destroyed And yes I replaced the weather stripping.
I found mine under the carpet by the rear seats. It too was destroyed by water. But I do have the sheet of options under the console lid. The lid had been replaced but the old owner taped it back onto the lid. Isn't another common place for the sheet to be in the seat upholstry?
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
Mine was in the trunk under the carpet. I've also seen them on the bottom of the passenger or driver seat, and under the carpet under the front seats.
I think I was a little overexcited when I found mine too.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I found mine under where the passenger would put his feet on the right side, above the cat-bump.
John
John
