What suspension???
Car: 91 RS
Engine: 305 TBI
What suspension???
I have a 91 RS with the 305 tbi. It has the z28 rims and i was wondering what suspension came with my car. Is it the same as the z28s or different and if not is it a decent suspension?
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Is the FE2 similar to the WS6 on the Pontiacs???
John
John
1LE had nothing to do with suspension. 1LE was brakes, AC delete, aluminum drive shaft and one or two other things I can't think of.
I do believe that FE2 may be the same as WS6 on the Pontiac cars.
On the Pontiacs WS6 is the better suspension. It has sway bars and the better steering box. 2.25 turns lock to lock. On early third gen TA's it mandated the inclusion of 4 wheel disc brakes. However later on that was no longer the case. I don't know about other specifics other than the suspension felt stiffer than non-WS6 cars.
Car: Take
Engine: Your
Transmission: Pick
My '91 Vert has WS6 and FE2. Since WS6 is dubbed "Level III Suspension" in all the sales brochures, that pretty much indicates that FE2 is Level III, which is the same code used for the upgraded Z28 suspension. F41 is the "Level II" and is standard on Trans Am's and Z28's.
LT1Formula
10-08-2015 08:34 PM
