Tire Wheelwell Scraping
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
I am running 245 50ZR16 Goodyear Eagle HP Ultra Plus tires now my prob is when I back up and turn left to a certain degree the tires will rub inside the wheelwell now I dont know why because these are the correct size tires. Any ideas on why or how to fix this? Sorry for posting in here didnt know where else to.
This is typical. Don't over steer and it won't happen. I think mine touches at full steer also. Have you checked for correct placement and installation of the inner wheel well?
No I have not checked that but I will and ill let you know.
Car: 82 camaro SC
Tires of the same size, do vary in actual size from brand to brand. Also, brand new quite a few 3rd gens rubbed when turning hard. Usually made worse when the owner swapped tires to another brand that was slightly wider in actual width. The good part is that you aren't hurting the tire--unless you are driving in constant circles with it rubbing.
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Also, Full alignments are different from car to car. Two identical IROCs may have very different settings for Caster, Camber, and Toe to align the vehicle.
If the Caster is set to the rear, the tire can rub then.
When my '85 Iroc had a blow out and took me over two curbs, things were so out of whack and un fixable, they had to set the Caster rearward as far as it would go. Thus I had to get 225/50/R16 tires so that I wouldn't literally peel the wheel well cover off.
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
My Roc tires also scrape on hard turns. I guess age might have something to do with it or not. I didnt have the car since brand new so i dont know if it did it from the beginning.
Words of wisdom...
Don't back up quickly with the steering cranked. I ripped a chunk out of the passengers side fender liner. Replacements (if they're available) are about $60 each side.
Keep an eye on where the tires are rubbing, if its frequent enough, the tires can rub thru the plastic, again costing you $60+ to replace them.
My red '88 GTA has rubbed since the day I bought it new, regardless of tire brand. It rubbed with the Eagle VR50s, it rubbed with Firehawk SZs, and it still rubs now with Firehawk SZ50s.... all in 245/50-16 size.
My black '88 Notchback rubs too.... with 245/50-16 Goodyear Eagle GT+4s on it.
The different steering box, noted by the letter "Z" on top of the box, was put into place to stop 16" wheels from rubbing on the sway bar.
Not to fix the Tire rubbing the fender on all cars.
Z boxes came only on Cars with factory 16x8 wheels.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
My Formula rubs a little, and it has the factory steering box, the 245's are a little wide... My solution may be to take out the inner fender liner and heat it up with a heat gun while trying to re-shape those sections where they rub. I have not looked at the attaching points to actually see if I can mold them or not.
John
John
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
