what models came with aluminum driveshafts?
this link should tell you everything that you need to know:
https://www.thirdgen.org/techbb2/search.php
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hey thanks a lot man! i already tried a search but you did a very good job pasting that link just the same.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I believe all of the 1LE's, and the TTA's came with it... Other than that I do not know.
John
John
Well if your 88-92 steel shaft was vibrating and you were still under warranty, then GM would replace it with an aluminum one.
Some GTA's and Formula's also came with the JG1 shaft.
That would make sense . I have a Black 88 I-roc and a buddy of mine had a maroon one . He was complaining about a hard thumping on the underbody in reverse so we changed the tranny mount and i noticed he had an aluminum shaft and i thought they only came on the 1LE
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
A bud of mine with a 92vert with a 305tpi/700r4 has the jg1 and it is a TA.
Originally posted by owned
Why in the hell would you put a cam into any engine that you didn't know the specs to? Do you dump any type of liquid into your gas tank?
lol no.. i got the cam from a friend of mine it was a few years old and he got it from comp cams(doesnt remember the part num or the specs, but its quite radical) used it for about a month threw a rod and took it out and put it in the box-o-parts.. when i got the car it was a 6 cy (someone couldnt figure out how to properly set valve lash and rounded off some cam lobes) so my friend offered it to me for free.. so in it went problem solved car runs like a raped ape
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
i have a 92 z 5-speed 305 tpi with t-tops, and i got an alum driveshaft ... it was even factory
Originally posted by nicksL98
just to correct Okfoz- tta's did not come with an aluminum d/s.
show me your Riv!!!
show me your Riv!!!
dustint209
11-26-2015 12:28 AM
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
topteam54
10-06-2015 12:21 AM
