RPO sticker
1 Post
Car: 1989 IROC-Z
i dont think its paint code
arent paint codes 3 characters, one of which is U?
ie: my 89 is bright blue metallic, code is 98U
it could be a second representation of the paint code i guess.
Car: Take
Engine: Your
Transmission: Pick
Thats the "Model Designation"
I beleive that translates to: (2)Pontiac (FS)F-Platform (87)2-door coupe
Starting in 1987, the VIN doesn't show the body style like it used to. Position 6 & 7 of the VIN used to show the body style. But in '87 and later, position 6 is the body style and position 7 is now a restraint code, so they put the body designation next to the VIN on the RPO label.
For example:
A 1986 VIN would look something like this:
1G2FW87....... Thats a Trans Am with the "87" body style (aka 2-door coupe). You could see the "87" body style in the VIN.
A 1987 VIN looks like this:
1G2FW21...... There is no "21" body style. Instead, the "2" represents all the 2-door hatchbacks: 07, 08, 77, and 87 and the "1" represents that it has Manual Seatbelts. So the "model designation" on the RPO label identifies it as an "87" body style.
Another example, my 1992 Trans Am convertible has the VIN of:
1G2FW33....... That means that its a Trans Am Convertible with Inflatable restraints. But my model designation is "2FS67" Wich means my body model is a "67" or two door convertible. If my Convertible would have been a "VIN verifiable" droptop made in '86, my VIN would look like this instead: 1G2FW67......
I hope this made sense....
For example:
Car: Take
Engine: Your
Transmission: Pick
My convertible has the paint code "45U" Dark Green Metallic, but if you look at the bottom of the sticker, it says: BCCC WA9539
That means that its a "Base Coat, Clear Coat" paint job, using Dark Green Metallic (WA 9539) paint. If you go to a paint store, they can mix you paint based on the 9539 code.
1 Post
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
Originally posted by GMTech
Paint codes end in "U", i.e. 98U.
Other parts will have their own codes. 55P, 64R, 47D, 19Q, 18E, 15P, 604, 60P, 75L, 21U, 13D, 82M, are all examples of thirdgen paint codes of various parts.
Pretty much any RPO starting with two numbers is a paint code.
Car: Take
Engine: Your
Transmission: Pick
Kizz, your right, there are other codes out there for other things, but usually when one says "paint code" I usually assume they mean primary exterior paint color. After all, like in some of your examples, I would hope we were not after a paint code for 47D Dark Red Cloth Trim combination. Not sure paint would work to well on that cloth
But to back you up, U is the "upper" or primary color, L is the "lower" or secondary color. P is usually the wheel color.
1 Post
Point well taken
unrelated: just to prove what I've said before about RPO generalization, etc. .. I wanted to mention that 47D is nothing to do with red; at least not in 1982 and the car I got it from, which is a 1982 Firebird S/E in Light Jadestone with Light Jadestone interior in Parella cloth, which is what 47D refers to. The color is an extremely pale shade of green/blue, closer to green though. Similar to the background color on the FbodyCD.com pic on the top of this page. Can see the car here.
gt
gt
Car: Take
Engine: Your
Transmission: Pick
Kizz, sometimes I think GM just does what they want to with RPO codes. My RPO book from GM only lists that code as being a red interior from 1976 to 1999. The book also says that the infamous "LG4" was a 5.0L 4bbl engine and a 7.8L Turbo Isuzu inline 6 diesel. Are these typos in the book or something that happened at the factory? We may never know...
1 Post
Every RPO and documentation book I have ever read has dozens of omissions and errors. Simply put, I don't trust books, unless I can verify their claims with real cars. See attachment for 47D Light Jadestone cowl plate. I would bet that Light Jadestone Firebird is one of THE worst documented thirdgens out there. Regardless, it did exist 1982 and 1982 only. A friend and I estimate that they made just a couple of hundred. The color is documented in every piece of 1982 literature like brochures, dealer books, etc. Not that I trust those any more, but at least they are from the horse's mouth, written at the time the cars existed, not decades after.
More importantly, see the URL I posted above.. for tons of pics of the car, inside and out.
1 Post
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Kizz --
That is the second Jade colored F-body I have seen. There is another one in a junkyard that I frequent. The first time I saw it, I was like "Green interior?!?!"
After a few more trips, I always stop and look at it -- just for the novelty that it is.
Thirdgen89GTA
11-26-2015 11:04 PM
