trans am or gta?
Car: Looking
trans am or gta?
i just bought a new car, the guy i bought it from told me it was a 91 firebird formula, i knew it wasnt from the hood, gf-x and everything, since its all original, except rims. but anyways, the car has been repainted and has no emblems on it, it has the usual stuff. option 3 fully loaded. t-tops. 305 tpi /auto, aluminum drive shaft. ws6 suspension but i just want to know if its a t/a or gta. the title just says 91 pontiac FTG (what does that mean) and 2h. the VIN is 1G2FW23F0ML226567 if anybody can help me i would appreciate it.
thanks
thanks
most states don't recognize GTA's as a separate model, but FTG could be Firebird Trans Am GTA, but i don't know if i'd put much on that.
if you have the RPO label i believe Y84 is the GTA code. (check www.gtasourcepage.com for more info, it's pretty comprehensive)
i'm not sure about the 91-92's, but the 87-90 GTA emblems on the nose actually had a hole/peg that centerd them, so there might be a small hole if it's missing on a GTA that wouldn't be there on a Trans Am. all GTA's should have the lumbar seats, (but trans ams could have them too).
Car: Looking
the RPO codes
heres all the codes im pretty sure its just a regular old t/a, with nothing special, but i want to be sure, before i go and buy the emblems for it.
AAA : 4-WAY MANUAL SEAT ADJUSTER
AH3 : ADJUSTER, 4-WAY MANUAL, DRIVER SEAT
AJ3 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BC8 : ORNAMENTATION, INTR, DR MAP POCKETS
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DC4 : MIRROR I/S, R/V, TILT, DUAL READING LAMPS
DE4 : SUNSHADE, REMOVEABLE HATCH ROOF
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
D42 : SHADE, RR COMPT SECURITY
D7C : GEAR, SPEEDO DRIVEN
D8N : SENSOR, VEH SPD
D81 : SPOILER, RR, AERO WING
E5Z : SPEEDOMETER ADAPTER (DELETE)
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
GU2 : AXLE REAR, 2.73 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
IPC : TRIM- INTERIOR DESIGN
JG1 : SHAFT, PROP, ALUMINUM
J42 : BRAKE SYSTEM, PWR. FRT DISC, RR DRUM, ALUMINUM
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 : GENERATOR,105 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NP5 : STEERING WHEEL, LEATHER WRAPPED
N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
PW7 : WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
QLC : TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
Unable to locate code R6A in our database!
T93 : LAMP, TAIL & STOP, SPECIAL
T96 : LAMP, FOG
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UQ1 : RADIO PROVISIONS, FOR STEREO
UX1 : RADIO, AM/FM STEREO CASSETTE EQUALIZER
U62 : SPEAKER SYSTEM, DUAL COAXIAL
U75 : ANTENNA, POWER, RADIO
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
Unable to locate code VIB in our database!
V73 : ANTENNA, FIXED
WS4 : MODEL CONVERSION, TRANS AM
WS6 : PERFORMANCE PACKAGE, SPECIAL
Y83 : MERCHANDISED PKG, TRANS AM
1SC : PACKAGE, OPTION 03
1SZ : ???
18P : WHEEL COLOR, CHARCOAL MET (91)
45Q : MOLDING COLOR, MED GREEN MET (91)
45U : PRIMARY COLOR, EXTERIOR, MED GREEN MET (91)
6ZX : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
66C : TRIM COMBINATION, CLOTH, MED BEECHWOOD (C)
66I : INTERIOR TRIM, MED BEECHWOOD (91)
669 : SEAT BELT COLOR, MED BEECHWOOD (9) (91)
7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
thanks
T96 : LAMP, FOG
1SZ : ???
thanks
1 Post
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
not sure if this is right, but:
V1B : DISCOUNT VALUE PACKAGE
was a valid code as of 1990. "VIB" has something to do with mobile phones..
The_Phoenix
02-04-2016 07:10 AM
