need more info on RPO E5Z, E9Z, and 1SC
Car: 05 GTO, 88 GTA, 98 SS
E5Z is a Speedometer adapter delete
E9Z in a speedometer key delete
1SC is package option 03 (what is this option?
Any help is appreciated.
What ARE these things?
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i know 1sc is referring to one of the option packages that gm introduced for the 1987 model year, i think.
iirc, 1sc was the rpo code for the "fully loaded" package that included most of the creature comforts. i'm not sure what all was included.
a search thru the technical database may spring up some leads into that.
The speedometer related deletes showed that an electronic speedo was used instead of a mechanical. The 1SC was the fully loaded options package. 1SA was the basic package, 1SB had more features and then came 1SC.
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: need more info on RPO E5Z, E9Z, and 1SC
Yes, I know it's an old post. But, I also have RPO's E5Z and E9Z, and I have a mechanical speedo, so I assume the related info Scott provided is incorrect.
Does anyone know for sure what E5Z and E9Z are?
I also have E7Z...
I also have E7Z...
3rdgenparts
05-21-2016 11:50 PM
Linson
10-01-2015 09:50 PM
