RPO code MX0?
RPO code MX0?
I wanted to see what exaclty came in my 86 TA, so I ran all my RPO codes...
AAA : 4-WAY MANUAL SEAT ADJUSTER
AK1 : RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR,
AM9 : SEAT, RR, SPLIT, BACK, FLDG
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01 : WINDOW, TINTED, ALL SHADED, W/S
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BV3 : ORNAMENTATION, INTR, I/P, BLACK
B20 : ORNAMENTATION, INTR, LUXURY
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
B67 : CONTAINER, RADI0 CASSETTE TAPES
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
B87 : ORNAMENTATION, EXTR EMBLEM FENDER---DELETE
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DK6 : CONSOLE ROOF, INTERIOR
D14 : ARM REST, FRT DR, RH & LH
D35 : MIRROR, OUTSIDE REAR VIEW
D42 : SHADE, RR COMPT SECURITY
D7C : GEAR, SPEEDO DRIVEN
D81 : SPOILER, RR, AERO WING
D88 : DECAL, STRIPE, SPORT
D9A : SENSOR, VEH SPD
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
GH3 : AXLE REAR, 2.77 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
K90 : GENERATOR,108 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
Unable to locate code MX0 in our database!
A5 : EMISSION SYSTEM, FEDERAL, TIER O
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
N33 : STEERING COLUMN, TILT TYPE
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N96 : WHEEL, 16 X 8, CAST ALUMINUM
PB4 : LOCK CONTROL, WHEEL
QDZ : TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9 : LAMP, GROUP
T93 : LAMP, TAIL & STOP, SPECIAL
T96 : LAMP, FOG
UF6 : LAMP, INTR, CONSOLE, COURTESY
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
UT1 : TONE GENERATOR, WARNING
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 : LAMP, INTR, RR COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U66 : SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL EXTD RGE
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
WS4 : MODEL CONVERSION, TRANS AM
WS6 : PERFORMANCE PACKAGE, SPECIAL
WW2 : APPEARANCE PACKAGE(SILVER), AERO #2
W62 : ORNAMENTATION, AERO PACKAGE
YR1 : SEAT,FRT CUSTOM
YS1 : SEAT,RR CUST
YT1 : BUILD UP DR & QTR
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
23Q : MOLDING COLOR, MED MAUI BLUE MET (91)
23U : PRIMARY COLOR, EXTERIOR, MED MAUI BLUE MET (91)
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7DB : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NM : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
82C : TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
84P : WHEEL COLOR GRAY (91)
88A : STRIPE COLOR, ACCENT, TWO TONE, GOLD/BLACK (91)
9NB : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
But as you see, mx0 isn't in the database, any ideas? Also, anyone know of a site that decodes these a tad better? There are a few I'm not sure what exactly they mean.
TR9 : LAMP, GROUP
T96 : LAMP, FOG
YS1 : SEAT,RR CUST
