Group Purchases Take part in, suggest, or discuss Group Purchases here. Make sure to read the rules before doing so.
Group Purchase on Greasable upper hinge repair kits
Old 02-16-2010, 12:40 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
A member of TGO requested for me to open a GP for the greasable upper hinge repair kits, which I've done. Once the quota of 20 kits is met I'll get them ordered. Remember, you MUST order under the GP part number to get the better price. If you're planning to do a hinge repair on your car, this would be the time to get them.
Lon Salgren
http://www.top-downsolutions.com/pro...roducts_id=120
Old 03-03-2010, 12:33 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Re: Group Purchase on Greasable upper hinge repair kits
I ordered mine about a week ago, is anyone else gonna order some?
Old 03-03-2010, 02:33 PM
AmorgetRS's Avatar
Ordering mine soon... problem is I start finding all these things I also need and the order gets expensive!
Old 03-03-2010, 04:42 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
+2 kits
Old 03-03-2010, 09:43 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
I ordered a pair for my GTA.
Old 03-03-2010, 09:51 PM
knight123's Avatar
Car: 1988 Firebird Formula
Engine: 5.7 TPI
Axle/Gears: 3.27 posi 9 bolt
interested but have no idea how this works - sorry - new here..can someone explain?
thanks
Old 03-03-2010, 10:24 PM
Steveh4263's Avatar
Engine: 5.7 LTR
thanks
Goto this web site and do some reading. http://andyz28.com/3rdGen/
He makes the hinge repair kits. But Lon is selling them at a discount with the group purchase. Thanks Lon!
Old 03-03-2010, 10:30 PM
mister_hudson's Avatar
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
Dang - I really need to get this but Uncle Sam has not come through yet... Hopefully it's still going on around the end of the month!
Old 03-04-2010, 09:48 AM
Steveh4263's Avatar
Engine: 5.7 LTR
You won't be billed until Lon get's the minimum order of 20 and the parts come. Once Lon gets the 20 orders and the parts come and the parts are shipped you will be billed. So order the parts now.
Old 03-07-2010, 08:57 AM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
If I go in on this, will I need any other parts?
I think the door spring is good, but I'll replace the lower hinge while I'm in there.
Old 03-07-2010, 03:39 PM
lonsal's Avatar
We're not clairvoyant, at least I'm not. You have the advantage of having the car there to inspect the hinge. Does the door detent arm jump on the door detent roller or make any popping noises as you close the door? That would indicate you need to replace the door detent roll & pin. You may find after doing the repair that you need to align the door due to the long heavy door bending the door hinge. I sell a door alignment tool. You won't know for certain until after you've done the hinge repair if you need the tool or not. Do you own a Dremel tool or air-operated die grinder? You'll need one of these to grind off the heads of the old upper door hinge pins.
What is your strategy to hold the door in place while you do the repair? I use a door hanging tool which jacks under the bottom of the car, has an arm that comes up to hold the top of the door and a post with a door latch pin to hold the door at the door latch. But that isn't something that everyone has in their tool inventory. Some tools that my customers commony used to hold the door are a floor jack (with rags or old towels covering the saddle to protect the paint at the bottom of the door). Someone can hold the door steady while you're doing the repair, but that gets tedious. One customer recommended using a ladder. Put the "A" of the ladder over the door, then stuff the gap between the door and ladder with towels. Some customers have an engine hoist (aka cherry picker) and use a nylon strap to hold the door up as they repair the door. Of course if these are beyond you, another strategy is to drop off the hinge repair kits along with your car at a body shop to perform the job.
Lon
Old 03-07-2010, 03:43 PM
Car: 1986 Trans Am
Engine: 5.0
Lon
Will probably use my engine hoist so it'll balance the door upright if I properly position a strap. I'll check out the other items you mentioned. If a part is reasonably cheap, I normally replace everything while I'm in there and plan on having to drive another vehicle for a few days as I know I'll forget something
I always overbuild, rather then half-*** everything.
Old 03-07-2010, 04:39 PM
Steveh4263's Avatar
Engine: 5.7 LTR
Door detent spring is $5.00 bucks very reasonable. I bought two just in case. I may go the body shop route for repair. Right now I just need the parts. Figure everything else out when the parts arrive. Lon how many orders have been made so far?
Old 03-07-2010, 09:14 PM
lonsal's Avatar
5 so far. 15 more kits to go, or 8 days. Whichever comes first. I've decided to hold the GP open 30 days, so those of you on the fence will need to make a decision. The GP closes 3/15 and the order placed on the 16th.
Lon
Old 03-09-2010, 12:09 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I'm in! Just have to wait till I get home to order. Damn filters on the work computer.
Lon, I noticed you now have power window motors, but you don't have a manufacturer listed. I have basicly seen 3 different motors offered, original GM replacements, cheap chinese replacements, and aftermarket "equals" to original GM. Any input?
Old 03-15-2010, 07:33 PM
lonsal's Avatar
GP has closed. The order will be placed today. I'll let you know when it is ready to ship.
Thanks to the four customers that decided to take advantage of the GP. I find it strange that you guys want a GP, yet the actual orders don't back up that fact. Regardless, I won't hold up those four customers and have closed the GP.
Thanks, Lon
Old 03-15-2010, 07:38 PM
Car: 1986 Trans Am
Engine: 5.0
Thanks, Lon
Looks like I was too late.
Old 03-15-2010, 07:42 PM
Engine: 305ci TPI
I blame Uncle Sam! Refund should have been here by now!
Old 03-15-2010, 07:51 PM
Stephen's Avatar
Car: 87 GTA
Thanks, Lon
Sorry.....It isn't that we don't want/need them, it's just bad timing for a GP.
Some people are waiting on tax refunds, others are having to pay not only income tax but property tax as well.
I'm one of those who have to pay this part of the year, so buying "toys" is not an option for me. In a couple more months, I can order some. But hinges are not most only need right now, nor my biggest need. So since my doors open & close, they aren't a high priority at this point, despite how it takes me 2-3 pulls EACH time I close the door & they are rubbing my lower rockers bare. Good thing that's just plastic (ground fx) not steel that would rust from being bare.
Old 03-15-2010, 07:54 PM
lonsal's Avatar
Sorry I can't accept a two until the order has shipped. The order was placed just now, so we're talking about a minumun of 1 week before your card would have been billed. Then you'd have the float on the card depending on when your closing date occurs.
Oh well, maybe next year!
Lon
Old 03-15-2010, 08:01 PM
Stephen's Avatar
Car: 87 GTA
Lon
Not even sure what you mean by "card" or "float on the card".
I was just trying to explain to you why you haven't gotten more orders, this time of the year. That's all.
Old 03-15-2010, 09:02 PM
krisb410's Avatar
Thanks, Lon
WHAT!!!!! I've been waiting for a reply to my question on your power window motor!!!!! I was waiting for that before I paid for my order! Please contact me ASAP! I've PM'd and posted my question in this thread, and just tried to call the # on your websight.
EDIT: I just "checked out" and paid for my order (without the power window motor)
Old 03-15-2010, 09:09 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
How did I miss this???? I just found this thread now. Oh well, hopefully there will be another one at some point. At least the passenger door is the only one sagging right now.
Old 03-15-2010, 11:04 PM
lonsal's Avatar
card = credit card
Lon
Old 03-16-2010, 01:20 AM
Car: 86 Z28
yeah i was kinda surprised i was the first one to order a kit, and i wasn't the one who suggested there be a group purchase on them. come on you guys that are complaining about not having money, I'm a broke college student and I was able to order a kit...
Old 03-16-2010, 04:32 AM
Car: 1986 Trans Am
Engine: 5.0
card = credit card
Lon
credit cards are the work of the debbil
Old 03-16-2010, 09:32 AM
krisb410's Avatar
Thanks Lon, once again, top notch customer service!!!!!!!
Old 03-16-2010, 01:01 PM
AmorgetRS's Avatar
Doh, I can't believe I missed the post about the 8 days! It's what I get for procrastinating...
Old 04-08-2010, 10:12 AM
Steveh4263's Avatar
Engine: 5.7 LTR
How is the group order going lon? I think you said the manufacturer was having some trouble with the hinges or something? I tried to send you a email. But there must be something wrong with my email or yours.
Steve
Old 04-08-2010, 10:22 AM
Car: 86 Z28
I had e-mailed him yesterday and he said the manufacturer hasn't notified him of the parts being ready yet.
Old 04-15-2010, 03:26 PM
krisb410's Avatar
Alright!, just got an email stating they shipping today!
Old 04-15-2010, 03:41 PM
Steveh4263's Avatar
Engine: 5.7 LTR
I got a email as well.
Old 04-16-2010, 09:27 AM
Car: 86 Z28
I also got an e-mail
Old 04-21-2010, 07:51 PM
Steveh4263's Avatar
Engine: 5.7 LTR
Got on my hinge repair kits today. 04/21. Thanks Lon.
Old 04-25-2010, 05:45 PM
brentstransam's Avatar
I bought mine about half a year ago, i live in Ontario and it cost me a extra $100 wen it came to my house, something about brokerage fees and duty. but in all an awesome product.
Brent
Old 04-26-2010, 09:14 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
what was the gp pricing? i guess i found this post too late
Old 07-23-2010, 10:04 AM
XxWickedz28xX's Avatar
Sorry to bring up an old thread guys, but is there any chance we can get a second round for this GP?
Im ready to order atleast one kit.
Old 07-23-2010, 05:59 PM
Engine: 305ci TPI
Make it two!
Old 08-08-2010, 12:25 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I would be in for 2.
Old 08-08-2010, 12:34 PM
Stephen's Avatar
Car: 87 GTA
I'm up for getting a pair, if the timing was right for my wallet.
Old 08-08-2010, 02:34 PM
skinny z's Avatar
Add another pair.
Old 08-13-2010, 06:16 PM
  #42
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
I need a set too! I'm in if we can make it happen. Randy
Old 10-11-2010, 06:40 AM
  #43
dbeall's Avatar
Car: 1986 Iroc Z
Transmission: automaaaaatic OD
Axle/Gears: i think there is some metal left
I just installed a greasable kit on my olde 86 Iroc, the door is perfect..now
The job was easy, but had to weld the lower door-side pin bores because the pin was 'loose'. so i took the door off with a comalong, worked nice.
i did take a few pics.. A Pain in the Door !
Old 10-11-2010, 07:14 AM
  #44
lonsal's Avatar
I'm opening a new GP for the greasable and non greasable hinge repair kits. The GP's will close 11/14. The hinge repair kits will be ordered 11/15. I'll let you know when the kits have arrived and are ready to ship. If paying by credit card, your order won't be billed until the item ships.
Lon
Old 10-28-2010, 08:21 PM
  #45
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Hi Lon, just ordered two kits plus some other goodies to install them. Thank you for the GP discount. Support for us thirdgeners is always appreciated.
Seth
Old 11-24-2010, 02:41 PM
  #46
lonsal's Avatar
OK, we can close this thread. All the orders that have been paid shipped today. Thanks for your participation and support.
Lon Salgren
Old 11-24-2010, 05:17 PM
  #47
skinny z's Avatar
I guessed I missed it despite subscribing.
Old 11-24-2010, 06:10 PM
  #48
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
I wouldn't have noticed without you & skinny z posting today.
What discount % was offered?
Is you regular price the same as andyz28??
We'll be ordering 2 kits in spring--- may as well do both doors at the same time!!!
Old 11-25-2010, 02:57 PM
  #49
Me too, and I was the one was asked for a second GP. I never claimed to be the brightest bulb.
Old 01-25-2011, 04:43 AM
  #50
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
is there a new group puschase coming
Quick Reply: Group Purchase on Greasable upper hinge repair kits
