86 Trans Am
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
86 Trans Am
Selling a 86 trans am that was going to be another project but i decided against it. (buying a house now)
car is straight appears to have never been in any accident the body is in good shape has one small spot of rust on the driver rear wheel well.
Was a 305 TPI (LB9) but a PO put in a 350 with a holly intake and edelbrock carb
Runs and drives as is
I have the RPO sticker
both headlights flip up
still the original 700r4 auto
rear disk brakes
16" wheels
C & C T-tops
Power windows and locks
rear defrost
factory Sub woofer option
clear coat is coming off bad and someone tried to repaint a portion of the drivers quarter gray, but it has no bondo probably a bad attempt to deal with the clear coat
interior is pretty rough
spedometer does not work
has aftermarket gauges for temp, oil pressure and volts
and someone put a manual toggle switch for the electric fan
good WI title
located in cudahy WI, 53110 just south of Milwaukee
$1500 as is OBO
rear disk brakes
16" wheels
C & C T-tops
rear defrost
good WI title
$1500 as is OBO
1992 Trans Am
05-10-2023 07:19 PM
