[VT] 85 Trans Am
Car: 1985 Trans Am
Engine: Procharged Small block 355
Transmission: TH-350 modified
Axle/Gears: Richmond 410
85 Trans Am
Selling my 85 Trans Am. Got it a couple years ago drove it 386 miles. Decided to pull the engine and found it was going to cost too much to do what I planned on doing. Also someone stole my supercharger and carb. So would rather see someone get good use with it. 0 Rust 0 Rust. Body is in decent shape has the usual dings/dents. I don't have the time to finish it. Does not run, engine is out. Can give you the block, it's apart or add your own. Comes with nice drag rims and tires, (rear tires brand new) Has a fiberglass cowl hood as well. $1500 firm again 0 rust 0 rust
Can be reached email or phone 802-829-9730
Does have the rear end, and gears as well
Car: 1985 Pontiac Trans Am'
Engine: 305 LB9 V8
Axle/Gears: 3.23 9bolt BW
Re: 85 Trans Am
Can you send me some pictures of it? 207-974-9671 or just post them on here?
Engine: 305 LB9 V8
1992 Trans Am
05-10-2023 07:19 PM
