[FL] 87 firebird gta 5.7 tpi 6spd
Car: 85 firebird
Engine: 4.8 lsx
Transmission: th400
Axle/Gears: 8.8 ford 3.08
OK selling my 87 gta. It has a lt1 6spd in it with a spec stage 2 clutch with about 2k on it now. BMR trans crossmember with torque arm relocation mount. Car has a 6month old aeromotive stealth fuel pump, about 4 month old bmr front and rear sway bars, alluminum radiator, longtube headers, cai, 9 bolt disc rear with a ta performace diff cover with pinion support. Thats all the extras i can think of the water pump was changed about 6months ago also with new belt. Car has about 100k on it. Factory burgundy hardtop car with gold emblems, interior is the baboon *** red interior with digital gauges. Interior is in pretty good shape. Body wise there is no wing but holes are filled. the paint is factory and clear coat is coming off and there is some bondo on the front right fender, front right of hood. The car ran good befor with the exception of the valve seals are shot now. posting for $2800 now as is with the valve seals. Car does still run and could be driven were it needs to go. If I do the valve seals price will be $3200. This would be the perfect time for someone to pick it up and swap a decent set of heads on it. 863 409 9016 call or text. i have exterior pics of the car i can text but none on computer yet. located in lakeland florida
Sanjay
08-12-2015 04:41 PM
