[FL] 1989 Trans Am GTA 5 spd 350 Supercharged $3200 (CLOSED PER OP's REQUEST)
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
1989 Pontiac Trans Am GTA $1800 OBO
White with gray leather
350 TPI 5 spd
Ran 14.2s at 97 mph (2004)
Approx. 128+K miles on chassis
3rd owner, owned since 2000
Call or Text 321-720-5085
Prefer text before 5 pm
Lots of pictures, walk around and driving video can be found at the link below.
http://s1112.photobucket.com/albums/...ansAmGTAWhite/
Test drive link:
http://s1112.photobucket.com/albums/...tTestDrive.mp4
Let me know if the link doesn't work or you need (smaller) pictures e-mailed directly.
Over $3000 in aftermarket performance parts alone!
Engine:
S&S Rebuilt truck roller 350 .020, .010 over, less than 20K miles
Comp Cams 214/220 cam p/n 104124 compucam 2032
Fluidamper SFI approved
Comp Springs p/n 99848
Speed density conversion, Moates EPROM adapter (chipped)
New fuel pump (10/2010)
New dist, cap and rotor (10/2010)
XS torquer starter
Hooker 1 ¾" long tubes
Custom dual cat y-pipe
Hooker muffler
Drivetrain:
Spec stage 2 clutch
T-5 WC 5 speed
Pro 5.0 shifter
Custom trans crossmember
Aluminum driveshaft
'96 trans am rear end 3.42 gears
TA aluminum diff cover with cap support bolts
Front Suspension:
KYB adj struts
Moog ball joints, tie rods, pitman arm and springs
Poly sway bar end links and control arm bushings
Solid tie rod adj.
New master cyl (8/2011)
Rear Suspension:
BMR adj. torque arm
Hotchkis adj. panard arm
Weld in sub-frame connectors
Metco solid aluminum lower control arms
Lower control arm brackets
Moog Springs
Comp Eng drag shocks
Misc:
Stock Gold wheels with center caps and lug caps
Original emblems except front bumper
A/C works well converted to R134A
Bad:
Misc body damage, rust, odometer, head light motors, trunk latch, headliner, right blinker, 5-4 downshift is not happy, speedometer is approximately 10% slow
350 TPI 5 spd
Test drive link:
Engine:
XS torquer starter
Hooker muffler
Drivetrain:
Spec stage 2 clutch
T-5 WC 5 speed
Pro 5.0 shifter
Aluminum driveshaft
Front Suspension:
KYB adj struts
Solid tie rod adj.
Rear Suspension:
BMR adj. torque arm
Moog Springs
Misc:
Bad:
Re: 1989 Trans Am GTA 5 spd 350 Supercharged $3200
everything looks awesome except the body! Can you email me some higher res pics? Hotroddin1320@gmail.com im very interested! is it daily drivable? or could it make a 1000 mile roadtrip?
Engine: LS7
Supercharger is sold. Car is now converted back to 730 code and has working A/C.
Cleaned up a little (hood vents installed, radio cover and climate controls in correct places.)
I'm going to re-post this ad with the updated price. Moderator can lock or delete this thread.
