[OH] 88 trans am gta w/ lots of parts.
Car: 90 Camaro RS
Engine: small block
Transmission: TH350
88' Pontiac Trans AM GTA. It is project car but will not take too much to get it on the road. I'm just tired of not finishing it so i thought i would see if anyone is interested. Black interior, no carpet or headliner. The engine bay was smoothed out by welding up all of the holes, removing the battery trays and painting it. the rest of the body still needs finished. LR quarter panel, and panel behind the tail lamps need repaired due to rust. small rust on hatch and left door. but over all the body isn't bad. 165,500 miles
The parts list includes:
Brand NEW:
-Spohn- tubular k member, tubular a arms, coil overs with new upper strut mounts, sub frame connectors, trans cross member, torque arm that mount to the cross member, adjustable wonder bar, adjustable bump steer tie rods
-brand new 350ci engine block with edelbrock rpm heads and intake, edelbrock hydaulic roller cam(#2204 duration @ .050: intake 234 exhaust 238/ lift @ valve: intake .539 exhaust .548/ lobe separation 112) estimated at 415hp-430hp, comp magnum roller rockers, and a demon 750 double pumper.
-SPEC stage 3 clutch
-kyb adjustable struts
-c5 corvette front brakes with cross drilled and slotted rotors and braided brake lines
-c6 zo6 motor sport wheels. black with polished lip and rivits. 17" 18" combo sumitumo tires on front, none on rear
-off brand racing seats that mimic a $1500 cobra seat
-reman brake master cylinder
-all new steering linkages. the idler and pitman arm were shortened for quicker response
-8 point roll cage. just tacked in right now.
-polly sway bar links, motor mounts and trans mount.
NOT SO NEW:
-T-56 six speed out of a 97 camaro z28 with aprox. 70,000 miles
-hurst shifter
-aluminum driveshaft
-rebuilt quick ratio steering gear box
-ac delete box
-so many more parts .................
Asking $6,500. I am located near Dayton ohio
Brand NEW:
NOT SO NEW:
-hurst shifter
-ac delete box
bigjay89gta
10-15-2015 08:04 AM
