[CO] 1989 Firebird 383 stroker supercharged
Car: 1989 firebird
Engine: 383
Transmission: 6 speed
Axle/Gears: ford 9" 410
it has a 383 striker supercharged with a t-56 6 speed tranny with viper internals, Holly stelth ram intake. inter cooled pro charger with a teal 50mm blow off, AFR 195 heads, roller rockers, H-beam rods, forged dished pistons , forged eagle crank, 30lb accel fuel injectors, 58mm BBK throttle body, center force flywheel and clutch, ECM fron a 91 cyclone with the chip burned to run a v8, slp line lock, 6 point roll cage, pro comp drag shocks in the rear, KYB adjustable shocks on the fount, drive shaft loop, tranny blanket, ford 9" rear end, 4.11 gears and moser 35 spline axles , Detroit locker, msd 7al box, msd 2 step, 5" tack with shift light, AC is cold and ready, Ram air hood, black interior is in great shape, red paint is good but could use a 2 coat of clear but there is lots of wax on it to make up for it ,,, there is a small ding on the driver door ans a scratch on the right finder ,, there is around 2700 miles on motor and trans and 200 or so on rear end, has been to the track 15 times or so with a best of 11.4 at 124 with a 1.5 60' with 9 lbs of boost ,, it is now set up with 5lbs boost and runs low 12's with a 300lb driver, motor was built to hold 20+ lbs boost it is around 8.5 to 1 ,,,, NO joy rides only people with cash ,,there is over 22000 into this car... i have a few pic but cant get them on send email for a pic 11,000 best
Car: 1989 firebird
Engine: 383
Re: 1989 Firebird 383 stroker supercharged
may trade for a 69 camaro all drag car
Car: 1989 firebird
Engine: 383
9000. If I can't get that I will part it out
Car: 1991 Pontiac Firebird
Engine: 3.1L V6 (just stock for now)
Transmission: Automatic
If you want to part it how much for the engine and transmission?
mhatfield 14
10-24-2015 07:48 AM
Mickeyruder
09-02-2015 02:45 PM
