92 formula 305 tpi tremic 6-speed
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i dont want to sell my 92 formula but being out of work some toys must go,
i have a white 92 formula 110k miles on it t-top, black interior, about 6k on the tremic tko t-56 trans, spohn torqure are and extream driveshaft, car has all new calipers[ all 4] all rotors, pads, kyb gr2 struts and shocks, be cool rad, edelbrock water pump, jet fan switch, slp headers, [duel cat set-up], borla cat back, slp runners, slp cold air intake, 52 mm bbk throddle body, corvete cover on the back of the plenum, firehawk rims [ white inserts] all new gm power window motors door regulators, outer window felts, poly sway bar end links,
bad part of the car original paint starting chip on the hood, headliner starting to fall,
i have a set of black gta rims or factory formula rims i can put on the car to drop the price, i can also put the original 5-speed trans and center console back in, to due the same,
asking $6500 or best offer,
will trade for a blue 91-92 trans am with a stick, stock or as close to it as possible is fine with me,
here is my cell # 1-732-330-5508
Car: 1984 Trans Am
Engine: 383 4 bbl
Axle/Gears: eaton posi w/ 4.11's
Transmission: auto
Re: 92 formula 305 tpi tremic 6-speed
it possible would come with the trans, shifter, spohn torque arm set up and the drive shaft, make me an offer, i would like pick up but i could look into shipping it,
i have all of the stock 5-speed stuff to put back into the car.
Sanjay
08-12-2015 03:41 PM
