86 TA 305 TPI 700R4 Hard-top No rust- Las Vegas
Car: '86 TA 305 F, '89 GTA 8
Engine: F 305 TPI, 8 350 TPI
Transmission: 700 r4
Grey cloth interior with new headliner.
Engine runs strong and smooth, with no leaks 190K original miles, requires 91 octane fuel.
Upgraded cooling system off of 89 GTA, including dual fans, baffle, air deflector, new Modine 2-core aluminum radiator.
Ugraded Air intake tubing from Air-box to Throttle-body off of 89 GTA.
Ported Plenum.
Paint is not so great anymore is Black with a red racing stripe around it.
Front bumber, Hood and both front fenders have small dents in them but have replacement parts for them. As I was going to repaint the car.
Upgraded sway-bar to 36mm WS6, with after-market steering brace installed.
16" Formula wheels with 2 new front tires.
I got a set of GTA rims in good condition (black) with brand new tires available for an extra $400.
Viper alarm.
4-wheel disk brakes with New Brake Booster/Master Cylinder/Front Calipers and Pads.
A/C compressor is bad, but rest of system OK.
Y99 level 2 suspension with 2.72 gears.
Tinted windows.
Car never in major wreck, I have had the car for 12 years, have repair receipts.
$2000
PICS on the way.
Ported Plenum.
Viper alarm.
Tinted windows.
$2000
PICS on the way.
Re: 86 TA 305 TPI 700R4 Hard-top No rust- Las Vegas
Pics added, am getting it ready to get painted. Left side fender still needs to be attached.
Engine and Tranny and rear-end are good. This car is almost as fast as my 89 350 GTA. There were several variations on 86 TA's, this one has the 140mph speedometer, and the better Cam. I have gotten as good as 25mpg cruising on highway at 80mph with this car.
$1800 right now, if I paint it obviously will want more.
Car: 2011 BMW X5 35d (diesel)
Engine: 3.5 ltr twin turbo diesel, 425lb/ft
Transmission: 6 speed auto
Axle/Gears: All wheel drive
I've seen the car in person, it would be a good little project.
(post some larger pics, if you have them)
- Rob
- Rob
Some new pics.
And some more.
Drivers side fender has dent in it, still trying to get another one.
I re-did the pictures, so that they are larger.
In regards to my earlier description, I need to make several corrections:
The car is running fine on 89 octane fuel, at some point I thought it needed 91, must have been in the heat of the summer, before I made all of the cooling modifications.
Also the steering brace is an OEM one off of an IROC, not after-market.
After the drivers side fender is replaced, the body is straight with the exception of a crease about 5 inches long in the left quarter panel.
Car is wired for Amplifier and subwoofer.
New shocks.
New Fuel Filter.
Alt is bought less than a year ago, was Duralast with lifetime warranty.
New Fuel Filter.
Recap of new parts in last 6 months:
New Modine Radiator
New Alternator with lifetime warranty. (1 1/2 year Old)
New Fuel Filter
New Plugs
New Brake Booster
New Brake Master Cylinder
New Front Calipers/Pads
New Front Tires
New Oxygen Sensor
New Shocks
New Struts
New Battery
Car is ready to be painted the color of your choice
---- Has a dent in Drivers fender that is repairable -----
Motor/Trans/Rear end all good.
Upgrades:
Cooling:
L98 Dual Fans, Baffle, Air Deflector
160 Degree Quadra-bored Termostat
Trottle Body Coolant Bypass
Suspension:
Iroc Steering Brace
WS6 36MM Front Swaybar
Performance:
TPIS Air-Foil
Descreened MAF Sensor
Ported Plenum
L98/GTA Air Intake Ducting from Air-Box to Throttle-Body
16X8 Formula 20-Slot Wheels
Interior:
Tinted Windows
Viper Alarm
Aftermarket Speakers
Car wired for Full Sound System/Amps/Sub-Woofer etc.
Stock Options:
4-wheels disk brakes
The better 86 LB9 Cam
Power Windows
2.72 gears for Fuel Economy
Car Capable of being driven across country
$1900
New Modine Radiator
New Fuel Filter
New Plugs
New Brake Booster
New Front Tires
New Oxygen Sensor
New Shocks
New Struts
New Battery
Upgrades:
Cooling:
Suspension:
Iroc Steering Brace
Performance:
TPIS Air-Foil
Ported Plenum
Interior:
Tinted Windows
Viper Alarm
Stock Options:
Power Windows
$1900
All of the Body Work is done, ready to be sanded/painted
Got A/C Working.
$1700
Got A/C Working.
$1700
Sanjay
08-12-2015 03:41 PM
