1989 Pontiac Turbo Trans Am 20th Anniversary Official Pace Festival Car #11
Car: 1987 IROC
Engine: 5.7
Transmission: Automatic
Axle/Gears: 3:42
1989 20th Anniversary Turbo Trans Am Official Festival Indy 500 Pace Car #11 of 150.
Original Califonia car located in upstate NY.
Very rare and super clean, original white, camel cloth int., [1 of only 150 Festival Cars all produced with cloth interior - all festival cars were at the Indy 500 during the race, on display, pictured on the track and offered for sale to GM employees first], posi rear, air conditioning, original aluminum GTA wheels, AM/FM Radio cassette with steering wheel controls, cruise control, power locks, power windows, rear defogger, tilt wheel, factory 1LE Performance suspension & brakes. Original owners kit, Pontiac Historical Society documentation, original 20th anniversary wires, original Goodyear gaterback tires [were taken off at 16k], original cat back exhaust with flowmaster muffler and original dual chrome tips. This TTA has been well taken care of and is super clean everywhere. It looks and drives very much like a low mile version. Drive this rare collector muscle car for less than market value.
TTA factory specs: 3.8L, SFI Turbo V6, 4-Speed Automatic Transmission, Special posi rear, factory 1LE Performance suspension & brakes; GTA level III WS6 4 wheel disc 1LE brakes [large 12" vented front with dual-piston aluminum calipers]; larger 1LE 36mm front and 24mm rear stabilizer bars, larger baffled 18-gallon fuel tank, quick ratio power steering with special valving, cross-drilled crankshaft for improved internal oiling, 20th T/A cylinder head provides more efficient combustion chambers and added exhaust port flow, air conditioning, original aluminum GTA gold diamond spoke wheels in excellent shape, AM/FM Radio cassette with EQ and steering wheel controls, cruise control, power locks, power windows, rear defogger, tilt wheel, original cat back exhaust with flowmaster muffler and original dual stainless steel tips. This TTA has been well taken care of and is super clean everywhere. It looks and drives very much like a low mile version. Drive this rare collector muscle car for less than market value.
NEW parts: Battery, EGR valve, steel braided oil supply and return lines on Turbo, intercooler flushed clean, Fel-Pro intake and oil pan gaskets installed, AC Delco plug wires, plugs, ignition module, coil pack, air filter, synthetic oil change with slick 50 [always used], transmission and rear end fluids changed with Royal Purple, new horn, intercooler shroud, new lower air dam deflectors, new interior lights. TA-49 Turbo by Precision Turbo rated 800 CFM upgraded turbocharger installed - largest stock appearing TTA turbo, 3" Turbo intake pipe and 2.5" chrome intercooler to plenum pipe, Duttweilwer intercooler neck, Hemco intake plenum, cylinder heads professionally rebuilt 3 angle valve job added LT1 V8 valve springs 100 lb. seat pressure, 10% under drive crank pulley, NEW timing chain, NEW Melling lifters & Speed Pro pushrods, NEW GM head gaskets, upgraded timing cover with larger oil passages and high pressure oil pump, NEW progear double roller adjustable timing chain, NEW roller cam button prevents wear on timing cover and a NEW harmonic balancer.
I have the original 20th Anniversary Owners Kit including the factory windsheld banner; door decals; leather owners manual case; Firebird Trans Am Owners Manual; 20th Anniversary Owners Manual Suppliment; Pontiac TTA cassette; letter from Pontiac and 20th Anniversary key fob, Pontiac Historical Society [PHS] documentation, very rare original 20th Anniversary plug wires in excellent condition, original P245/50ZR16 Goodyear Eagle "Gatorback" tires [in good condition as they were taken off at 16k], correct GM floor mats with "Turbo Trans Am" custom embroidered in them, PACE 11 CAR festival plate, [2] GM 1989 Firebird Trans Am Formula GTA service manuals & special TTA service manual supplements, 1989 Official Indy 500 Program, Decals and Pin, original Pontiac 20th Anniversary Trans Am sales brochures, a folder containing all receipts and maintenance records along with PHS [Pontiac Historical Society] documentation including window sticker showing the delivery to Jim Weston Pontiac and a total of $31,198.00.
Viper alarm installed with a remote power lock and hatch release. Has smooth idle and crips shifts. This TTA was never raced, but has made some passes run at a local track and went 12.03 @ 118 in the quarter mile. The car has not been raised in excess of 20 PSI and runs excellent. Just passed NYS inspection [July '07]. This Turbo Trans Am runs very well and is a pleasure to drive.
-Chris
-Chris
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
1992 Trans Am
08-08-2015 08:16 PM
