Acronyms and their meanings
Automotive Terms
2BBL = Two barrel carburetor
4BBL = Four barrel carburetor
A2/3/4/5 = Automatic transmission, with number of forward gears
AFPR = adjustable fuel pressure regulator
AIR = Air Injection Reaction
ALDL = Assembly Line Diagnostic Link
BARO = Barometric Pressure Sensor
BDC = Bottom dead center
BW rear = Borg Warner rear
Cam = Camshaft
Carb = Carburetor
Cat = Catalytic Converter
CR = compression ratio
DIS = Distributorless Ignition System
DTC = Diagnostic Trouble Code
ECM = engine control module
EEC = electronic engine control
EEC = Electronic Engine Control (Ford)
EECS = Evaporative Emissions Control System
EFE = Early Fuel Evaporation
EGR = Exhaust Gas Recirculation
ESC = Electronic Spark Control
EST = Electronic Spark Timing
GM = General Motors
HEI = High Energy Ignition
HO = high output
IAC = Idle Air Control
IAT = Intake Air Temp
IP = Instrument panel
ISC = Idle Speed Control
LC = lock-up converter
LCA = lobe center angle
LCA = Lower control arms
LSA = lobe separation angle
M3/4/5/6 = Manual transmission, with number of forward gears
MAF = Mass Air Flow (sensor)
MAP = Manifold Absolute pressure
MAT = Manifold Air Temperature
MIL = Malfunction Indicator Lamp
MPFI = Multi-port Fuel Injection
PCM = Powertrain Control Module
PCV = Positive crankcase ventilation
PROM = Programmable Read Only Memory (chip)
ROF = Rolling on the floor (goes with the second one)
RPM = Revolutions Per Minute
SD = speed density
SES = service engine soon
SFC = Sub-frame connector
STB = strut tower brace
TBI = Throttle Body Injection
TC = torque converter
TCC = Torque Converter Clutch
TDC = Top dead center
TPI = Tuned Port Injection
TPS = Throttle Position Sensor (switch)
Tranny = Transmission
TV cable = throttle valve cable
VSS = Vehicle Speed Sensor
WOT = Wide Open Throttle
General Information
BTT = back to top
BTW- By the way
FAQ = Frequently Asked Questions
G/S = Grams per Second
IIRC = If I remember correctly
PPH = Pounds Per Hour
TGFBA = Third Generation F-Body Association
TTT = to the top
Just for fun
ATM = automatic teller machine
BAR =- Browning automatic rifle
BET = Black Entertainment Network
BOR = Box O' Rocks
Camaro = Classy automobile model allowing repeated orgasms
FU = Felix Unger
FUBAR = forked up beyond all recognition
GF = girlfriend
LAW = light anti-tank weapon
LMAO = laughing my a$$ off
LMFAO = Laughing my Fu**ing as off
LOL = laughing out loud
LOL = laughing out loud, but also, lots of luck.
Mustang = most ugly stinkin' turd available notwithstanding Gremlins
Newbie = Not Engine Wise But Investigating Enablement
Old Fart = Often Lives Daily For Asphalt Rending Tiresmokers
PITA = pain in the Ahzz
POS = piece of $hit
TLA = Three Letter Acronym
WFO = wide freakin' open
WTF = What The Fun
[This message has been edited by Chuck Everly (edited May 26, 2000).]
Cam = Camshaft
Carb = Carburetor
GM = General Motors
HO = high output
SD = speed density
General Information
BTT = back to top
BTW- By the way
TTT = to the top
Just for fun
BOR = Box O' Rocks
FU = Felix Unger
GF = girlfriend
POS = piece of $hit
WTF = What The Fun
1 Post
More Automotive terms:
Carb = Carburetor
[This message has been edited by 84ZZ4 (edited May 26, 2000).]
Carb = Carburetor
why are there 2 b's in 4bbl and 2bbl?
four barrel has one b!
why not 2bbl
and 4bbbbl
SAVE THE BIRD!
1987 Formula 350, Accel supercoil, cap, rotor. MAF screens removed. 160 degree stat and manual fan switch.
Custom dual 15 install by me and my dad
best ET: 14.745@91.317mph w/ sub boxes removed
"I want to show people other areas of myself that they may not be familiar with" -Christina Aguilera
why not 2bbl
and 4bbbbl
SAVE THE BIRD!
morrow
01-13-2024 12:29 PM
Damon
09-26-2015 04:29 PM
