Will V6 T-5 work with V8? Or vice versa?
Car: 86 Z28
Engine: '76 305 0.030 over
This one's popped up on the techboard. Heard the Q many times before. They're hashing it out over there, maybe the "final answer" (dorky Millionaire saying) should be posted in FAQ.
1 Post
Okay, here's the story.
In order to make a V6 T5 work with a SBC, you need the following:
V8 T5 bellhousing (the V6 bellhousing bolts are different)
V6 Clutch disc (the spline count and shaft diameter are different)
V8 flywheel
V8 pressure plate
I don't know which throwout bearing or pilot bearing you need to use at this point.
Also note that I have NOT tried this, because I think it's a huge waste of time and money and that you are better off getting a V8 tranny in the first place. Even the non-WC V8 T5's are probably stronger than the V6 ones.
V8 flywheel
V8 pressure plate
Guest
Posts: n/a
What he said. But the v6 clutch disk is also smaller than the v8 version I think. What one guy did was have the center section cut out of his new v8 disk, and the one cut out of his old v6 disk. Then he had the v6 center welded into the new v8.
v6 T5's do have the advantage of amazing gearing, but I don't think they are as strong.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Evil Ringleader of the Infamously Twisted SE Flordia Alchoholic Crew
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
