Speedometer gears for manual transmissions
1 Post
There's a big table on the A4 in the FAQ, but nothing for the T5. I've got a list of P/N for driven gears at home if it would help.
Yes, that would help me and Tom Keliher tremendously!! Tom is switching his A4 3.27 9-bolt for a T5, and needs the correct speedo gears for it, and my dad is replacing the rear end in his RS with a 3.27 9-bolt, and needs the speedo gears for his T5 as well. Thanks Ron!
On another note, I just replaced my failing T5 with another, and the speedo gears I pulled out for my 3.42 rear end, is a purple 7 tooth drive gear, and a white 19 tooth driven gear.
1991 Camaro Z28
5.7L 5-Speed
13.32 @ 105.27 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Webmaster: ICON Motorsports
1991 Camaro Z28
5.7L 5-Speed
13.32 @ 105.27 MPH
Southern California
1 Post
Ok, here are the drive gears:
14071731 Purple 7 teeth
14053347 Red 9 teeth
Driven gears:
18 Brown 3987918
19 Natural 3987919
20 Blue 3987920
21 Red 3987921
22 Gray 3987922
I believe there is a 17 tooth gear, which would be part no. 3987917, but haven't verified it, nor do I know the gear color.
I also have NO combination info, but if enough people start posting theirs, we can get some together...
Kevin, that DEFINITELY helps (purple/7 and natural/19).. FWIW, I believe that is the EXACT same combo that came out of my V6 tranny when I pulled it (also had 3.42s).
The new tranny I put in (WC T5 from a '91 or '92 RS with the 0.63 5th gear) had a red drive gear (9 teeth)
Anyone else????
[This message has been edited by 84ZZ4 (edited May 18, 2000).]
Driven gears:
18 Brown 3987918
19 Natural 3987919
20 Blue 3987920
21 Red 3987921
22 Gray 3987922
Anyone else????
ambainb
04-25-2016 09:21 PM
