Can I use a 400 crank from a BBC in my SBC?
A: If your SBC was made in 1986 or older you can use a 400 crank from a BBC, but you need to have the 400 crank reground...
I think I just screwed that up, so someone correct me because it's a question that should be included in the FAQ.
1989 Camaro RS L03 w/ T-5
Bitchin' Camaro, Bitchin' Camaro doughnuts on your lawn!
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
big block chevy? or 400 small block chevy. The BBC has a larger bore spacing than an SBC, did you know that? I think you ment a 400 SBC with a two-piece rear main seal into a 4.00" bore block SBC with a two-piece rear main seal, right? You can retro fit a two-piece onto a one-piece block, GM sells the adapter.
George P. Lara
1984 Z28 High Output
SC3GFB
SCFB
[This message has been edited by MRZ28HO (edited May 17, 2000).]
George P. Lara
SC3GFB
SCFB
Hotrodboba400
12-10-2019 07:07 PM
dimented24x7
09-06-2015 03:51 PM
