Fuel Tank Sump and Heat Shields
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
I have a 1990 IROC with a fuel tank sump installed. I am running dual exhaust with turn downs at the axel, and the fuel tank heat shields are removed. I want to install a Muffelx 4" single exhaust that will place the muffler back in the stock location. Does anyone here have this setup?Did you put your heat shields back on or how are you managing the heat from the muffler against the tank? I am thinking to cut a hole in the shield for the sump to fit through and bolting the stock shield back into place. Here is what my current setup looks like
Car: 1990 IROC-Z
Re: Fuel Tank Sump and Heat Shields
Great, thanks for the reply
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Check clearance on the panhandle bar, it's really close to the upper support. You will likely need to lower the axle side mount.
FormulasOnly
06-19-2024 12:07 PM
BrianChevy
04-19-2014 07:59 PM
