Home brew road racer resurrection
I havent posted in over a year but that doesnt mean the project was dead. On the contrary a lot of work has been done to the car and ive driven it hundreds of miles to verify that all of my modifications are working as they should. This is a picture of how the car stands as of now.
Catbox (06-24-2024)
Re: Home brew road racer resurrection
Wow, lots of rework in the front there. Are those widened fenders to fit bigger tires? How are you liking the FiTech setup?
As far as the fitech, I am very pleased with it. It took some time and effort to get it tuned properly but it really improved the in-town drivability over the Holley carb. Switching to FI from a carb will quickly show any inadequacies in your fuel delivery system. A lot of guys bad mouth Fitech and aftermarket tbi conversions, but i found most problems are caused by installer error and not the unit itself.
One of the problems that came about was my 5" offset inner tie rod mounts caused the rack to rotate up and down when initiating a turn. I couldn't really feel it , but noticed it while working under the car. To solve the problem i came up with a guide for the center link, that consist of 4 urethane wheels mounted to brackets attached to the r&p frame mount. The center link kind of floats between the rollers, allowing it to move up and down about an 1/8" total.
Another upgrade I did this spring was to install a remote oil filter and a large plate style oil cooler. Because of my cars low ground clearance I run a modified set of C3 vette headers that have been shortened in height by about 2.25". This left just enough room to screw on the shortest sbc filter I could find. Being that it was so short it wasn't ideal for oil filtration and sitting just 3/8" off the header pipes didn't help my oil Temps either. With the small amount of space I had to work with I ended up using a Transdapt flush mount oil filter adapter plate and 1/2" 90 degree fittings to get the oil in and out of the engine. The adapter plate comes with standard hex head bolts to hold the plate to the block, but my 90 degree fittings wouldn't clear the heads. To solve the problem I countersunk the bolt holes using a 45 degree chamfer bit and some 5/16" beveled Phillips head screws.
you can see in this pic just how little clearance I have between oil filter mounting pad and the top of the header collector.
All oil filter plumbing is -10 steel braided hose. The routing is output from engine to the remote oil filter, oil filter output to lower oil cooler fitting, and then oil cooler outlet back to engine inlet. Running the lines in this manner keeps any junk or bearing debri from getting into the oil cooler.
FITech has a magnetic controller mount now that works much better than the windshield suction cup one. It’s part number 62017. You could mount this right to your sheet metal dash.
I just bought one for my Ultimate LS controller. Hoping to figure out a way to mount this in a gauge pod on the A-pillar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
Wow just read through your original thread after seeing this resurrection! What a crazy amount of work, and welding, you've done, and dealt with the highs and lows of life and a project. Thanks for sharing and glad you are still working on this - cant wait to see whats in store! Cheers
ughmas (12-28-2022)
The radiator in the car lays forward at about a 45* angle. All the air to the radiator is ducted through the front grille. The electric fan is a 2 speed unit from a 1999 Gran Marquis. It fits the radiator core perfect, uses a big 19" fan and pulls big air, but also big amps. Low speed uses a 30 amp breaker and 50 amp relay and high speed uses a 50 amp breaker, a 70 amp relay with 8 Guage wiring. I run a 185 Stat and with fan on low car stays about 200 degrees whether 60* out on the highway or 95* stuck in rush hour traffic downtown.
I run a TKO600 in the car and really needed a working parking brake. My rear brakes are an aftermarket kit from SSBC and the calipers have an integral parking brake. When putting my interior together I retained the factory parking brake lever but it's now mounted between the driver's seat and the transmission tunnel. All I needed was an emergency brake cable kit to hook it all together. I used Summit Racing's universal kit and it worked well except I had to weld the cable to the factory eyelet to be able to attach the cable to the hand brake.
Factory parking brake lever mounted to floor just to the left of the brake proportioning valve.
Black bracket welded to trans tunnel anchors front cable housing.
Rear cables enter through rear firewall behind drivers seat.
Cables attached to my calipers with no problem. Clamped cable to rear axle tube flange.
Made a couple simple wire hangers to keep cables from hanging to low or getting pinched in coil over spring.
I've been mostly working on bodywork lately but also trying to get car ready for autox. I built this car thinking I'd run 11x17 C4 Vette wheels at all 4 corners but trends have changed and 17" tw200 tires are hard to find. I needed to step up to an 18" wheel and after much research decided C5 Z06 rear wheels would be a reasonable substitution. Watching Marketplace for several months I found four 10.5x18 Z06 wheels and tires. The rears mounted up no problem, but the fronts were close to touching the upper ball joint stud. I corrected this problem with 1/2" wheel spacers and 3" ARP wheel studs.
Right front tire just touches upper balljoint stud.
Looks pretty good with the 10.5x18 Z06 wheels.
This is clearance on right front after 1/2" spacer and longer studs.
Left side clearance after spacer. Left side has noticeably more clearance than the right side. Something isnt right.
After lookin at both font spindles carefully I came to the conclusion the the top of the right spindle was bent outward towards the tire. I have a spare set of spindles and pulled the the right side off the car to compare. Sure enough the spindle that I have used to build this front suspension around is bent. I replaced it with the non-bent spindle and it has moved the top of the tire farther out from the upper ball joint, basically giving me positive camber. I have enough adjustment to get my -1/2* camber street setup back but I'll have to relocate the upper mount to get -3" camber for autox.
Here you can see the difference in the bent spindle(rear), and non bent(front). The top half of the rear spindle is bent up towards the rotor. The top half of the front spindle lays flat, near parallel to the floor
I’m glad to see that you are still working on your project. I was starting to wonder if you had abandoned it. I hope to hear from you and see updates more frequently than every six months. The car is looking good, your persistence is paying off. If you are doing the body work, paint can’t be that far off. That’s when you start to get excited about the final product. I’m looking forward to it.
So I'm doing bodywork now, and I'm really not very good at it. I put too much filler on, then sand too much off, and have to do it again. Eventually it comes out ok. Here are some pictures of hood, deck lid, and my gutted doors.
Interior side of door showing sub-structure that mounts interior door handle.
Sheet metal panels installed and interior door handle mounted. In keeping with my "home brew" budget build, the metal panels are made from salvaged sheet metal shelving units. I have rolls of lightweight, gray, outdoor, carpeting that I will cover the door panels with. I'm thinking I'll have to use velcro strips to fasten the carpet to door panels.
Lots of filler, sanding, fiiler and sanding. These doirs were given to me free, so i didnt feel bad about cutting them up. Thet were however in rough shape, with multiple dents from being kicked to close and being repainted twice.
This is how the doors look now after 2 coats of heavy fill primer. There are some small air holes visible that I'll have to fill with spot putty before i block sand them, but definitely heading in the right direction.
This hood started out as a 6" Harwood pin-on unit that I cut down to a 3" cowl. These hoods are big, nearly 5'×5', and a real pain to remove and re-install by yourself everytime you want to check something under the hood. To get around that I made hinges that pivot at the A-pillars that allow the hood to open and the cowl scoop clears the windshied.
Here you can see the bottom of the hood. I boxed in the bottom of the cowl using 1/4" hardboard that i fiberglassed to the bottom of the hood. The hood seals to an 18" pan under the 14" air filter. I sealed the pan to hood with a section of garage door seal. This has turned out to be very effective in selling off hot underhood air as I have not seen intake air temps higher than 100*f even on 90+ degree days.
DynoDave43 (07-15-2023)
So I've been slowly getting some bodywork done on the car. I've got the gutted doors installed and then started on the front fenders. Besides having to fill in the 5" gap behind the relocated wheel opening, I had to do something to fix the excessive gap between the front edge of the door and the back of the fender. A second set of used fenders solved both problems. I was able to cut sections from the fenders to cover the 5"gap and I used the rear edge of the used fenders to extended the rear edge of the modified fenders tou close up the door gaps. Instead of welding the patches in I opted to try panel bond adhesive. That worked so much better, no worries about warpage from heat, so much faster.
Here you can see what im starting with, a 5" gap behind the relocated wheel opening and a large gap between door and fender.
Patch panels installed on right side. Still lots of body filler, shaping, and sanding to get ready for paint but just getting that large gap in the fender covered makes me feel like i got something accomplished.
The left side needed a little more work as the lower lip of the wheel well was pretty well rusted away. I used nearly 100 sheetmetal screws to hold the panels in place to insure a good, tight bond between the base fender and the patch panels.
Last edited by 83RDRACR; 08-20-2023 at 08:51 PM. Reason: I duplicated the previous post
I never wanted this car to be one of those grandeous, over the top builds that never gets finished. The plan has always been, build it, drive it, enjoy it. God has thrown me a few curveballs over the years and is continuing to do so, but I'll persevere and get this car to the track, hopefully this summer.
More bodywork and pics of progress.
Lots of body filler and sanding and shaping. Im pretty pleased how the flare is turning out.
So much sanding!!!!
Door gaps and belt line are lining up well.
A lot of work but it came out pretty good.
Drivers side came out well also.
So much sanding!!!!
DynoDave43 (03-06-2024)
With the fenders finished except for block sanding I turned my attention to the roof. When I got the car it had a dealer installed sunroof. It worked okay and didn't leak, but it didn't fit with the road racer look I'm trying for, so I took it out and welded in a tight fitting patch. Even though I used hundreds of tack welds over 2 days, trying not to warp it, it still sagged and puckered really bad. The inner roof support was cut out when the sunroof was installed so there is nothing supporting the roof panel and helping hold its shape. I welded in three 2x34 16ga strips to the underside of the roof, while using a small bottle jack to push the roof skin up. Of coarse when I removed the jack the roof sagged some but not as bad as before. To hold the roof skin up and allow me to adjust the curvature I made some adjustable supports out of 1 1/4 angle iron and 5/16 carriage bolts.
I made a template of the curvature of the roof.
The adjustable supports were welded to the halo bar of the roll cage.
Here you can see the supports welded to the halo bar. The long carriage bolts push up against the 16ga strips . The strips help spread the load across the roof so it doesn't "tent" up just above the bolt head.
WildCard600 (03-06-2024)
So, another day spent out in the garage. I've pretty much got the entire roof roughed in and shaped. I put a guide coat on before I stopped for the day. I'll lightly sand over it tomorrow to find the high/low spots.
The following 2 users liked this post by 83RDRACR:
DynoDave43 (03-07-2024), ughmas (03-07-2024)
I didn't take pictures as I smoothed out the roof, but basically I ran a 6" orbital sander with 40 grit over the roof to rough up the old paint and show the high and low spots. The high spots I tapped them down with a hammer and the low spots I filled with a fiberglass based body filler. When the fiberglass dried I covered the entire roof with a thin coat of the fiberglass filler and let it dry. I then used the 6" orbital to sand down the fiberglass and work on getting the curvature of the roof back. After 2 applications of the fiberglass and sanding, I switched to a lightweight body filler. Again 2 coats with sanding in between and the roof is looking pretty good. Hopefully more progress tomorrow.
ughmas (03-07-2024)
8P
So I've been working on the body now fo
r a few months and am finally getting to the end. Fenders and doors were painted a couple days ago and all the rest of the removable body parts will be painted by the end of the week. Seeing how the doors and fenders turned out makes all of the hours spent shaping and sanding the panels worth while. Feeling excited. More pictures later.
ughmas (07-15-2024)
Finally, after 14 years, the car is one color and looks good. It is very close to how I envisioned it when I first started planning this build. The car is far from finished but this is a big step forward.
gt4373
10-13-2017 09:16 AM
gt4373
09-21-2016 11:06 PM
