led taillights
Car: 1987 camaro sc
Engine: lg4 305
led taillights
im gonna attempt to make custom lights in the shape of the chevy bowtie and a mirrored image of it for the passenger side of the car. it will have one for brake and running lights alternating leds for them. the next one inside of it will be for reverse. and the third inside of it will be for turn signals and 4 ways. i have started to fill the void were the black stripe is so i can make a negative of the lenses.
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
stock taillights are temporarly filled to make a mold of the lenses need to pickup a heat gun to shape the lexan. all the leds and resistors are ordered just need to wait for them
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
oh yea this is what im planning on doing the tops is drivers and the bottom is passenger. the black bowtie is what is going to be reverse lights. the bowties are gonna fit alot nicer in each other with led
Car: 89 GTA/90 Iroc Vert
Engine: 5.7/5.0L
Transmission: 700R4 x 2
Axle/Gears: 3.27/2.73
Re: led taillights
I got a whole bunch of these bowties if you need some.
Selling them 2/$12 inc shipping.
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
im making the bowties out of led when i get them. do you think the taillights would look mirrored like that in the pic i posted or them both facing the regular way
Engine: 5.7/5.0L
Re: led taillights
Either way wb cool, mirrored seems more custom IMO.
Post up some finished pics and how you built it, neat project.
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
made a basic negative for the pass side today gonna do the same for drivers tommorrow using some of the lexan i have
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
got the second negative done the leds should start arriving soon
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
recieved the amber leds, 100ohn, 470ohn, and 1.5k ohm resistors in the mail today. now just have to wait for the red leds, white leds, and the 220 ohm resistor
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
got everything and finished seeing how bright they accually are. whites going to be 3 leds with 1 220 ohm resistor reds are going to be 3 led 1.5k resistors for running and 470 ohm resistors for brake lights. and ambers are going to have 470 resistors. definately gonna notice the lights when done
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
Re: led taillights
I'd like to see how this turns out, I had a similar idea months ago and never followed through
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
cut the pieces were the leds are gonna get mounted in got 48 of 146 drilled. theres gonna be 48 10mm red leds for brake and running, 56 5mm white leds for reverse, and 42 10mm amber leds for turn signals. per lense
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
heres the led holders for the taillights all the holes drilled into it gonna paint it black so you can see the leds clearly
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
hopefully by the end of the night i will have at least the brake and running in one of the lenses and working
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
heres some pics of it now. 1st pic is the running light circuit with 9 volts 2nd pic is how the leds are wired together
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
reverse lights on the taillights couple leds not lit bc i didnt solder them at that point just twisted it around the power feed.
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
heres a video of the taillights 1 panel is finished showing running brake reverse and turn
http://s260.photobucket.com/user/lmi...03409.mp4.html
Re: led taillights
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
to think i got the idea while just drawing random stuff in school
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: led taillights
Those look pretty good. Looking forward to seeing them when you have them mounted and functional.
Car: 1987 camaro sc
Engine: lg4 305
Car: 1987 camaro sc
Engine: lg4 305
Re: led taillights
my question is if ones like these were being sold how much would people pay for them.
1 Post
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
Re: led taillights
what id like to see are some nice sequential LED taillights that cost less than $700
If you can find a cost effective way to make LED taillights there would definitely be a market, albeit a niche market, but still a market.
Re: led taillights
I have LED sequential tails in my Camaro right now, they are not a full LED board like OP, but LED bulbs. If you did the same light board style and use BigBadLou's sequential system on the power supply you have yourself a sequential LED board for decent price.
Car: 84 camaro Z28
Transmission: borg warner T5
Re: led taillights
do you have pics of those?... that has to look awesome..
Car: 82' Z28 Crossfire
Transmission: Turbo 350
Re: led taillights
#43
Re: led taillights
I can't find the original thread, but BigBadLou makes them and ships them for $56 and gives you instructions too. He was even nice enough to walk me through on the phone as the wires in '82 were a little different.
As far as I know, this is the last thread written about them, it is a bit dated but he may still have a few left.
https://www.thirdgen.org/forums/elec...als-batch.html
#44
Re: led taillights
btw, this is not a whole new taillight system, just a small device you run all of your wiring through to alter how the taillights function. As you may have noticed in the video, I have no stock reverse light due to this and had to make my own, other than that, they are great, haven't had an issue yet.
#45
Re: led taillights
#46
Re: led taillights
custom, you can have a paint shop do it for you, but I just bought VHT red and blackout. Painted the turn signal and reverse lights red until all the lenses were the same shade and then blacked them all out.
#47
1 Post
Car: 1990 Camaro RS
Engine: 5.0L
Transmission: WC T5 5-speed
Re: led taillights
I've been looking at these for my '90:
Spaghetti Engineering Digi-Tails
There's a video clip on the page that shows them "in action". Price is $319.00 plus shipping.
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
RedLeader289
05-28-2019 01:47 PM
