single housing headlight mod
Car: 1992 Camaro RS
Engine: 1978 L82 355
Good afternoon thirdgeners!
Today I was able to do a little modding to my headlights. I went to the salvage yard and got some headlights off of an late 90's Olds. Can't recall the exact model, but I found a perfect set for a swap of the stock 4x6's. I have not been able to get the brights to work yet, will have to require some wiring.I did swap the high and low beam selection to make it a little more unique. Here's a few pics, let me know what you think! I will post pics with them on when it get's dark this evening.
Car: 1992 Camaro RS
Re: single housing headlight mod
Shoot. Just realized that I put them on the wrong sides according to the third picture. Eh, guess we all have brainfarts at some point.
Car: 1992 Camaro RS
Here's some photos while lit. Didn't have a chance to take a before and after photo comparing them to stock but it is quite a bit of a difference!
to the op how easy did thouse housings mount up, are the solid or do they wobble around a lil bit
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Good job it looks factory! Has anyone tried aftermarket type lights? Rather then the stock style? It will give the lights a look like the year one bandit car
![](https://www.fquick.com/images/articles/13651.jpg)
I doubt there is much of anything aftermarket for most of those early 90s GM econoboxes. But there is plenty for 88-98 GM trucks. Depending on specs of coarse.
![](http://turbometal.com/media/catalog/product/cache/1/image/e5f6a4e1639bf7fac402bcd89a7988b3/P/R/PRO-YD-CCK88-C_7.jpg)
1 Post
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
that looks awesome.. Good job..
![](http://www.fquick.com/images/articles/13651.jpg)
![](http://i.ebayimg.com/t/88-98-GMC-SIERRA-CHEVY-SILVERADO-2500-CHROME-GLASS-LENS-HEADLIGHTS-TAHOE-NEW-/00/s/ODUwWDg1MA==/$(KGrHqR,!i4F!MKS5EPqBQN(npIujQ~~60_35.JPG)
Car: 1992 Camaro RS
They fit pretty well. Had to drill some holes in the camaro housing to be able to mount them temporarily with cable ties, and they are pretty snug in the mounts. Gonna be a lot easier changing bulbs.
Car: 1992 Camaro RS
Can also switch back to stock anytime! Very simple ans easy. Hardest part was pulling them off the donor.
what bulbs do they take , wanna price up some hid conversion kits
Car: 1992 Camaro RS
I am not sure off the top of my head, they are sylvanias though. I can double check when I have a chance.
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Looks like a early 90's cutlass head light ..... Early 90's cadillac devills had the same design too
Back years ago someone on here used bertta headlights too
here is a pair on flea bay brand new
http://www.ebay.com/itm/87-96-Oldsmo...d0705b&vxp=mtr
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
If I'm not mistaken the C/K headlights are actually slightly smaller. what you have seem to fit pretty dang good. I like it a lot.
Car: 1992 Camaro RS
Thanks man! It took an hour of walking through pull a part with a tape measure to fine some that were close. I also tried some off of an early 2000 astro van that would've looked great if they were about a half inch wider.
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
one of the things i like about my camaro is that it doesn't have the newer plastic lenses that have to be maintained.
havent had to touch them for over a year anda half now and still look just as good as when i did them
dbrochard
10-03-2015 12:43 PM
