radiator support rubber padding?? any ideas?
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
i guess this is the best section for this.
Looking for ideas on what i can use for padding, rubber cushion for my radiator and support. My radiator is not in the stock location i have fabricated a new support for it, its 3" alum wide rad that sits on 4 1"x 2" steel. looking for something clean and neat
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: radiator support rubber padding?? any ideas?
I use gasket maker (high temp) for spots that are close to rubbing in places. I put a huge Griffin rad in my 90 ZR1 and had to grind out the pad holders in the bottom to make room so I ran lines of gasket maker on the rad and lined the rad cavity with gasket maker and that was in 1998 and it is still in there with no problems and it cools awesome.
I woul use dense foam with sticky backing. Clean the areas with alcohol and stick it down.
You can use camper foam...like that you'd use for between a truck bed and a camper shell. OR...you can use something from Home Depot. Like door sealing strips. Can usually get that stuff in different thicknesses and widths. If you lay it nice and straight it'll look great...what little you'd see of it. And you can always pull it off if you have to.
Whatever you use, make sure its the dense stuff because it will compress some, but not all the way, and have a "memory" to it. Should work well.
J.
J.
1992 Trans Am
05-10-2023 07:19 PM
CarGuyDennis
137
12-06-2016 11:02 PM
ambainb
04-25-2016 09:21 PM
