Homemade Camaro gauge cluster rings
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Hand cranked on a manual lathe...
![Name: 2012-04-04171141.jpg
Size: 161.0 KB](https://www.thirdgen.org/forums/attachments/fabrication/372473d1501384643-homemade-camaro-gauge-cluster-2012-04-04171141.jpg)
![Name: 2012-04-04171130.jpg
Size: 97.4 KB](https://www.thirdgen.org/forums/attachments/fabrication/372474d1501384643-homemade-camaro-gauge-cluster-2012-04-04171130.jpg)
![Name: 2012-04-04171155.jpg
Size: 264.2 KB](https://www.thirdgen.org/forums/attachments/fabrication/372475d1501384643-homemade-camaro-gauge-cluster-2012-04-04171155.jpg)
![Name: 2012-04-04171111.jpg
Size: 298.8 KB](https://www.thirdgen.org/forums/attachments/fabrication/372476d1501384643-homemade-camaro-gauge-cluster-2012-04-04171111.jpg)
![Name: 2012-04-04171148.jpg
Size: 348.4 KB](https://www.thirdgen.org/forums/attachments/fabrication/372477d1501384643-homemade-camaro-gauge-cluster-2012-04-04171148.jpg)
![Name: 2012-04-04171116.jpg
Size: 126.3 KB](https://www.thirdgen.org/forums/attachments/fabrication/372478d1501384643-homemade-camaro-gauge-cluster-2012-04-04171116.jpg)
![Name: 2012-04-04171102.jpg
Size: 106.8 KB](https://www.thirdgen.org/forums/attachments/fabrication/372479d1501384643-homemade-camaro-gauge-cluster-2012-04-04171102.jpg)
Just need to do two more smaller rings for the center gauges
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Re: Homemade Camaro gauge cluster rings
Thanks man... I'm thinking about it...but its pretty time consuming to make these
Those are pretty cool. Make them out of aluminum and anodize them different colors.
I think aluminum looks the best
COTM Editor
Those look awesome! I have always thought that I would use Twist Machines gauge bezels if I upgrade to aftermarket gauges at some point. I def try and sell them... I'm sure you got a buddy that could write a program for them and spit out pieces for you with a lot less time involved.
Might think of a similar design to this if you continue with this....
Car: 1987 Trans Am
Engine: LQ9/L92
those look very nice, I remember someone had done something similar for the bird dashes. good way of upgrading the look of the dash without having to get all new gauges.
![](https://encrypted-tbn1.google.com/images?q=tbn:ANd9GcSKd-EKPIhk5zB0rrFhppb31Cog5aqRKoTLQmB7DV2sPvqihvI6)
![Name: spacegauges.jpg
Size: 289.0 KB](https://www.thirdgen.org/forums/attachments/fabrication/372365d1501384440-homemade-camaro-gauge-cluster-spacegauges.jpg)
yup iv seen them before too they look really nice i wish i could go thicker and wider but i'm limited on the space... I agree that's why i made these rings. Im keeping most of the interior stock but tweaking everything to make it look more exotic
Thanks... Once i'm done turning the two other small rings ill look into making more i think
Transmission: Pro-built 700R4
1 Post
Car: 92 Z28
Engine: Boosted LSX
OP those look good.IF your interested PM me if you do decide to make more. I might be able to help ya out. (cnc lathe made ) Im making a set and a totally diff. design as a 1 piece look where all the round guages interconnect where they get close to each other.
Yep, Ive made a few of those sets sold on here along with a few other things in aluminum.
The problem is most people say I want, I want. but when it comes time to buy in. Not many do. This is my everything I do now is One off parts when I get a serious interest.
http://www.cecoatings.com/images/Billet%20Parts/
The blueprints where a great guide but i had to change nearly all the measurements to keep from toasting them on the lathe... turning these on a manual lathe sucked... to bad you didn't want to make me a set... but thanks again man!
Car: 88 iroc
Engine: 305 tpi
Transmission: unknown atm
Axle/Gears: unknown atm
They look great, kinda look like they could be stock part, they don't seem out of place. Like some.gauge rings ive seen.
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
anymore update! got me tuned in for sure, looks kinda like something you'd see in a 1st gen IMO
Car: 1991 Z28
Engine: 5.7 TPI
These look incredible for a manual lathe from the Medieval Machine Shoppe! You are a craftsman, sir! This was the kind of stuff you would see knocked out all over in the 1960s, but no one seems interested in doing artisan stuff like this anymore...and then we come across guys like this!
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Those look good. I'd like to see some installed.
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
imo they would look better if the front part was narrower.but post a pic with it installed.i may be wrong.
Car: 89 GTA/90 Iroc Vert
Engine: 5.7/5.0L
Transmission: 700R4 x 2
Axle/Gears: 3.27/2.73
They look great Luis, I may have to buy a set for the Iroc ...
Luis did a great job on the T/A rings- they fit perfect, look great.
