Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Ultimate trailer hitches
Old 02-09-2013, 04:47 AM
  #51
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: Ultimate trailer hitches
You are talking to your self again
Old 05-22-2013, 05:09 PM
  #52
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I have a trailer similar to what you can get at Harbor Freight. Have been looking at making it into a DIY "tear-drop" camper. Lots of good plans just from Googling.
Curt's hitch should be more than I'll ever need, but I'd want this if the price was similar. This should actually add structure to the car, IMO.
Old 05-24-2013, 03:13 PM
  #53
On Probation
Atilla the Fun's Avatar
Engine: several
Transmission: none
Axle/Gears: none
Still available, still $150. idcsr1@aol.com
Old 05-24-2013, 08:25 PM
  #54
cosmick's Avatar
Sold!
Old 07-30-2013, 01:16 PM
  #55
atterack833's Avatar
Engine: 6.5 turbo diesel
Transmission: 4l80e
Axle/Gears: 3.21
Originally Posted by Brando5641
LMAO the gooseneck is well..... nvm
Not going to lie, that is a stupid idea with the gooseneck. I know its your car but you might as well give it to a dirt track guy and let him F-it up.
But hell yea I want to see pics, i really want to see some of your hitch that didnt cut up the rear bumper.
i think he can do the goose-neck but he should make his own notch back , thats one part there arnt many of around and even if he does it right its still butchering the notchback , unless he has it resesed and rais it up for towing then it would only look like a notch back when its not towing , make sure you have clearance for the trailer to swing
Old 07-30-2013, 01:40 PM
  #56
Transmission: 4l80e
Axle/Gears: 3.21
saw your hitch , love how you mounted it above the subframe for support , mine im ataching to the sides and the mounts for the rear end , if i start towing heavy ill brace from there to the k member or the cross member
Old 08-17-2013, 09:24 AM
  #57
TGO - 10 Year Member
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
can you get Reese hitch any more for a 1983 trans am or is curt my only option ?
Old 08-17-2013, 12:13 PM
  #58
DIGGLER's Avatar
i would think most any real load on one of these cars would twist it up. the only structural part of the body is made up of ~1/16" steel. its basically nothing.
the max weight you can put on a f150 gooseneck pin is around 1500lbs, i believe. and that should be located a few inches foward of the rear axle centerline.
not sure how much weight you would be able to sit on a camaro in that location, but i would figure something like 600lbs would have it close to the bumpstops. your average gooseneck trailer would probably put 300lbs on there by itself.
its just not enough car. i pulled my racecar with a '99 2500 for a few years and i ran into some scary situations on more than one occasion where i didnt know if i was going to get stopped. thats a 3,000lb car on a ~1500lb car trailer. my truck was about 5800lbs, this car is more like 3500-3800lbs. even if you locked down all 4 wheels, a 4,000lb trailer would be fine pushing the car wherever it wanted. another thing is never trust electric brakes on the trailer. they are temperamental and unreliable. when cold they might not work at all on some trailers. this is an interesting build, but i think it will look like a pile of junk when complete, and still not be able to haul very much. something people would take pictures of and post on the net. lol
i would like to see it though. lmao
Old 08-17-2013, 06:20 PM
  #59
Transmission: 4l80e
Axle/Gears: 3.21
thought he was done
Old 08-19-2013, 03:24 PM
  #60
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
This idea reminds me of the Corvair. A radical new idea that will undoubtedly be 'Unsafe at any Speed'
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
mattcanty
10-12-2015 11:08 AM
92projectcamaro
09-29-2015 07:07 PM
drumstixer
09-29-2015 03:02 PM
manifoldsrme
09-17-2015 11:40 PM
Quick Reply: Ultimate trailer hitches
