transmission crossmember I fabed up
I decided to fab up a new transmission crossmember using my old one, I'll add a few pics, let me know if you like it or think it wont work? thanks
Attachment 235441
Attachment 235441
Car: 1987 Trans Am
Engine: LQ9/L92
Re: transmission crossmember I fabed up
very nice looking setup. if it clears the frame rails there, should give you some more room to tuck up the exhaust and save yourself some ground clearance
1 Post
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Looks like you did a good job!! I'd buy one from you if I went that route. I smell a small buisness maybe? haha
all i did was put the old crossmember up in place marked a line to know where the frame rails are in relation to where i would have to add the pipe, i used a peice of 4" abs pipe so i could get the proper fit, then cut the steel pipe to fit, I did weld the steel pipe in place before i cut the lower section out so it didnt warp, then i welded to under side. primed and painted it! glad you like it. thanks
Ok I put it in place for you so you could see how it fits, when you put your crossmember in place, mark your lines to follow the frame rails, then mark another line in about 1/4 inch to allow for your welds, and about 3/4 inch on the drivers side for fuel lines, ill help and answer any questions you guys have, thanks
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
It looks like a good solid idea that you had. I like it and may look at doing that myself when the time comes. It sure is simple with the way you fabbed up with ABS first. Great job.
hey thanks, I love to build things myself, and I think everyone should build there own stuff as well, not only does it look strong it is strong, i know when i build tinngs myself it will be good, better than some after market peices out there, thanks again
The great part of this is that it can be done quickly and with the trans in the car. Small modifications made and it should work for most any transmission.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
That looks great! nice job!
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I tried fabbing one of these but the pipe on passenger side was to large for my tail shaft to pass by, 4l70e. Also the mount is in a different location on the newer model trans, which made the tailhousing hit.
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
thats a nice pice you made great idea i will have to copy yours when i do my exhaust next spring thanks for sharing!!!
ok guys change of plan, only just got the motor in the car, got a family life to haha so car has to wait, anyway I'm going with a t56 now, so ill be selling this cross member, have to build one for that now, something similar I guess,
dustytrix mine works flawlessly, never hit anything! takes a fair bit of fitting and measurements to get it right.
customblackbird I used 3/8 I think I can check. thanks
TOMcat GTA
09-15-2015 09:31 AM
3rd, 53, 84, build, camaro, chevy, crossmember, crossmembers, exhaust, fabricating, fbody, gen, put, speed, trans, transmission
