Another pop up headlight delete...
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 formula
Engine: 350tpi
Axle/Gears: stock posi
About two years ago I decided to get rid of the bug eyes... I dont have have any picture of where i welded a frame around the hood out of 1/4"x1/2" flat steel and then cut out a headlight cover duplicate out of 20ga. steel and welded them both to the hood... here are some during and after pics...
![Name: 33999_1480183375392_1558044378_1201936_5171759_n.jpg
Size: 55.1 KB](https://www.thirdgen.org/forums/attachments/fabrication/375286d1501390248-another-pop-up-headlight-33999_1480183375392_1558044378_1201936_5171759_n.jpg)
![Name: 33999_1480183335391_1558044378_1201935_1202563_n.jpg
Size: 56.9 KB](https://www.thirdgen.org/forums/attachments/fabrication/375287d1501390248-another-pop-up-headlight-33999_1480183335391_1558044378_1201935_1202563_n.jpg)
![Name: Picture002.jpg
Size: 62.4 KB](https://www.thirdgen.org/forums/attachments/fabrication/375288d1501390248-another-pop-up-headlight-picture002.jpg)
![Name: Picture001.jpg
Size: 80.7 KB](https://www.thirdgen.org/forums/attachments/fabrication/375289d1501390248-another-pop-up-headlight-picture001.jpg)
![Name: Picture003.jpg
Size: 61.2 KB](https://www.thirdgen.org/forums/attachments/fabrication/375290d1501390248-another-pop-up-headlight-picture003.jpg)
![Name: 426331_3226398349675_1558044378_2972790_2025293041_n.jpg
Size: 48.1 KB](https://www.thirdgen.org/forums/attachments/fabrication/375291d1501390248-another-pop-up-headlight-426331_3226398349675_1558044378_2972790_2025293041_n.jpg)
![Name: front.jpg
Size: 94.8 KB](https://www.thirdgen.org/forums/attachments/fabrication/375292d1501390248-another-pop-up-headlight-front.jpg)
under the hood.
![Name: underheadlightjpg.jpg
Size: 52.7 KB](https://www.thirdgen.org/forums/attachments/fabrication/375293d1501390248-another-pop-up-headlight-underheadlightjpg.jpg)
what do you guys think?
![Name: front.jpg
under the hood.
Car: 85 trans am
Engine: 355
Transmission: t56
Axle/Gears: 4th gen 4:10 eaton posi
Re: Another pop up headlight delete...
what are you going to do for head lights i like the look so far
Car: 87 formula
Engine: 350tpi
as soon as i finish painting this rsx im working on, im going to start working on a fiberglass housing. probably just paint it silver on the inside and a smoked lexan cover in front, with HIDs. nothing super fancy...
i also want to extend the ground effects maybe 2 inches all around the car and have the front bumper level and not in an angle upwards... that more towards the summer...
1 Post
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
I like pop up headlights better, but this isn't a bad look.
Car: 87 formula
Engine: 350tpi
thanks. I dont like the pop up look at all, even though my old ones never failed..
1 Post
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Cannot wait to see the finished product! Have you seen my headlight delete thread?
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
1 Post
Car: 89 GTA
Engine: 5.7 TPI L98
No problem! I can send more pics too if you'd like. Something like my setup would work perfectly for the creator of this thread.
https://www.thirdgen.org/forums/fabr...ctors-gta.html
1 Post
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I like this look a lot. Not sure if you've seen red reifs POP up delete, but a combination of this and his and I think its a Sharp look. Can I get more info on what you used and how you did this. I'm really into this conversion bro, gives it that old devilish 70s look.
-matt
-matt
Car: 87 formula
Engine: 350tpi
sorry for being so late on this.. i got lost for a while lol I used 1/2" flat stock and 22ga. sheet metal.. If I were to do it again Id used maybe 16 ga.. 22 is too thin... I bet and welded the flat stock onto the hood then kinda bent up the sheetmetal and welded it.. grind it, short strand fiberglass and body filled the rest... Im thinking of fiberglassing the hood and making it.. nice winter project.. these hoods are already like 80 pounds..
Car: 87 formula
Engine: 350tpi
looks nice.. that look like what I had thought of first... My dad threw away the mold for the housing I had made >
now I need to work on another one... Im thinking of doing air ride and widening the quarterpanels about an inch this winter..
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
1 Post
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Well I cheated with my head lights, And its funny you should mention widening your rear by an inch,
mine are an inch an a half wide, both the backs and the fronts,
Here's what I used for my head lights, I got them of ebay
they are for a Nissan 240 sx and I modified them to work .
What did you use for your lights?
![Another pop up headlight delete...-new-ta-lights.jpg](https://www.thirdgen.org/forums/attachments/fabrication/249424d1482197780t-another-pop-up-headlight-new-ta-lights.jpg)
![Another pop up headlight delete...-picture-96.jpg](https://www.thirdgen.org/forums/attachments/fabrication/249425d1482197780t-another-pop-up-headlight-picture-96.jpg)
![Another pop up headlight delete...-picture-18.jpg](https://www.thirdgen.org/forums/attachments/fabrication/249426d1482197780t-another-pop-up-headlight-picture-18.jpg)
Car: 87 formula
Engine: 350tpi
ahh nice.. im still unsure on if I want to widen just the wheels flare, or the whole thing... do you have a write up on yours or pictures on how you did it?
1 Post
Car: 1987 Trans Am
Engine: 355 tpi
I haven't done a write up on this yet, I'm waiting until the car is totally finished then I'll do a build thread on the whole project, But I do have some pics, from the type of flares I used, , pics of the test fit before I cut out the the wheel wells and molded them in, And then decided to modify them more because they just needed a little bit more.
the flares are actually for a first gen mustang , nothing to modify just added fiberglass to make them a few inches longer. And widen them a bit at the bottom , the back wheels are 17x11 with 285, 40's with a 3 inch adapter, those wheels actually fit the front with a 2.5 inch adapter under the wheel wells, with no rubbing what so ever, so they are going to go on once I get my new back wheel, 17x11 with 335, 35 for the back and I'll be changing to 2.5 adapter on those .
If you want any more pics and info on my car you can email me at patrick_day24@yahoo.com, I don't want to take up your thread here, on my stuff,
![Another pop up headlight delete...-558612_275453049199201_966495829_n.jpg](https://www.thirdgen.org/forums/attachments/fabrication/249434d1482197780t-another-pop-up-headlight-558612_275453049199201_966495829_n.jpg)
![Another pop up headlight delete...-298490_177979875613186_232951625_n.jpg](https://www.thirdgen.org/forums/attachments/fabrication/249435d1482197780t-another-pop-up-headlight-298490_177979875613186_232951625_n.jpg)
![Another pop up headlight delete...-ta.jpg](https://www.thirdgen.org/forums/attachments/fabrication/249436d1482197780t-another-pop-up-headlight-ta.jpg)
Car: 1999 Formula Hardtop
Engine: 6.2 forged ls3 Procharged
Transmission: t56 Magnum
Axle/Gears: midwest chassis fab 9/3.50
i think its a cool idea, but the execution is bad, the work done looks bad .
1 Post
Car: 1987 Trans Am
Engine: 355 tpi
who are you talking to? If it is mine You have NO idea what you are talking about,, Actually who ever you are talking about, Shows you nave no clue of what you are talking about and You should keep it to your self
I'm talking to the op. he asked What we thought. Botto
Of first post. Learn to read.
Car: 87 formula
Engine: 350tpi
Probably looks bad because I dont have pictures of how I framed it and then welded sheet metal under the filler... true that I am no master metal fabricator, or no filler would of been necessary..
