gauge/switch panel out of old ecm case
ok so i started on my gauge/switch panel
the aluminum housing is the bottom of a stock ecm case, this will bolt up under the center heater/ac vents
figuring out the gauge location and switch locations
drilling the holes for the oil presure and volt gauge
and them installed with the aem and boost gauge location layed out
need to run out and buy a 2 inch holesaw to get those holes drilled, and also pick up some toggle switches
and down the left side from top to bottom will be my switches for
#1 ignition
#2 fuel Pump
#3 nitrous arm
#4 antilag momentary push button switch
i left room between switches 1&2 and 2&3 incase i need to add anything in later
#1 ignition
#2 fuel Pump
#3 nitrous arm
1 Post
Car: 87 Camaro
Re: gauge/switch panel out of old ecm case
Looks pretty nice I can't wait to see how you mount it.
On a side note I have that exact same ancient remote for my vcr
its just going to have 2 bolts comming down threw the heater vents, omce i get the toggles wired up and boost gauge and my aem wideband mounted in it ill paint it black and show u how i mount it
and almost finished up my gauge/switch panel ( open hole is going to be for my boost gauge or an aem tru boost, havent decided on if im going to get a tru boost or ams 1000 yet) yreah i know my ecu has built in boost control but i dont like how its setup
Hotrodboba400
12-10-2019 07:07 PM
