stock rear springs with mini tub
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
has anyone mini tubbed acar moving springs inside frame rails if so do you have pics im thinking about doing using 3/16 plate if ido ill post pics
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: stock rear springs with mini tub
where would you put the gas tank?
never seen it done. why not
just use a smaller diameter spring in the stock location?
Engine: 468bb
Transmission: 700r
Car: 1991 RS
Engine: 5.0
Check out this thread. It has links to other members cars who did what your trying to do. Some good info and pics to go off of.
https://www.thirdgen.org/forums/fabr...-tub-kits.html
Engine: 468bb
Transmission: 700r
what are you looking to use for tires? are you using stock style suspension? you will have to move the shock mounts and the control arms too. Your almost to the point of a back half.
Engine: 468bb
Transmission: 700r
i want to tuck 315/60/15 drag radial under fender lip
you can do that without doing anything as drastic as moving the springs to the other side of the frame.
A typical minitub with smaller springs will accomplish this.
if you look around, either here or in suspension, a few people here use that size tire.
Engine: 468bb
Transmission: 700r
Engine: 468bb
Transmission: 700r
Im using 2.5" springs with weight jacks on the back of 92 for that matter.
Engine: 468bb
Transmission: 700r
you have helped me alot on ithank you very much iwas going to build 73 nova but ithink ill finish my camaro instead
why not both, novas are cool too
sailtexas186548
08-26-2015 03:32 PM
1988iroc350tpi
08-14-2015 07:52 PM
