Custom amp rack
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
Custom amp rack
I ran into a small problem when it came to hiding the amps in my car . I am going for a factory modified look and I highly doubt the first place GM would have bolted a couple amps is right there on the hump out in the open . So I came up with this .
![Name: 105_0479.jpg
Size: 21.4 KB](https://www.thirdgen.org/forums/attachments/fabrication/398366d1501435675-custom-amp-rack-105_0479.jpg)
Holds both of my amps securely and fits perfect in the rear compartment on the drivers side, with the removal of the cardboard insert that is.
![Name: 105_0475.jpg
Size: 20.4 KB](https://www.thirdgen.org/forums/attachments/fabrication/398367d1501435675-custom-amp-rack-105_0475.jpg)
![Name: 105_0476.jpg
Size: 18.4 KB](https://www.thirdgen.org/forums/attachments/fabrication/398368d1501435675-custom-amp-rack-105_0476.jpg)
![Name: 105_0477.jpg
Size: 22.2 KB](https://www.thirdgen.org/forums/attachments/fabrication/398369d1501435675-custom-amp-rack-105_0477.jpg)
There is no need to make any holes or do anything to damage the car . I will post up more pics test fitting it a bit later .
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Custom amp rack
That looks pretty cool. Seems that is a good spot for the amps. The only thing I'd suggest is make sure your hatch weather stripping is good (and doesn't leak). I've had one or 2 puddles in that spot before...
Engine: 5.7 TPI
Re: Custom amp rack
True but Im not to worried about that . This car will never see anything but sunshine with me .
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Re: Custom amp rack
I like it. I'm all for keeping everything stealth. No one needs to know what we have done to our cars. I hate people looking inside, you never know if they are a car guy or looking for easy pickings.
raymondandretti
09-27-2015 06:43 PM
