2k hp capable street car build
#501
Car: 1986 Camaro
Engine: LS6
Transmission: Tick Stage 2 T56
Axle/Gears: Moser 12 Bolt
Re: 2k hp capable street car build
Holy SH*%! What a car! I don't even care there's a ford powerplant in it. It's just so amazing! Good job with the car! You have mad skills! If you ever bring it to Houston, I would love to see it!
#503
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
wow there's just so much fabrication on just the simplest things. its such an awesome build
#504
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Installed a vibrant vanjen clamp. will hold 100 psi, and allows up to 12 degrees of movement.
#506
Car: 1999 Formula Hardtop
Engine: 6.2 forged ls3 Procharged
Transmission: t56 Magnum
Axle/Gears: midwest chassis fab 9/3.50
very awesome build . has it been dynotuned yet .
#507
Car: 1990 formula
Funny you ask... tried to dyno monday night. As soon as the turbos spooled it would drop holes and spit and sputter... 640 rwhp on 8 psi.
It pulled 9% fuel out and was still around 8% rich. Made a couple more pulls messing with timing and fuel and it did the same thing.
I thought it was weird, because it never misfires on the street, so unloaded it off the dyno and made a couple highway blasts... ran a 5.36 second 60-130 going uphill, dunno the slope of the road.
I think it's obviously making a lot more than 640 rwhp.
#508
Dynos dont load the motor like street unless its one of the best load bearing mustang types but even still its not same. Makes sense why it dyno rich. Need to try lean dyno tune and then put your street tune back on once its off the dyno or else risk goin to lean and burning pistons
#512
Car: 1990 formula
Going to try to make it to the 1/8th mile track this weekend, and have the Texas Invitational roll racing event the weekend after.
#513
Car: 1990 formula
Here's a preview for the TI event. Should be lots of video!
http://www.google.com/url?q=http://w...FuItby-ckYcGYw
#515
Car: 1990 formula
The weekend went pretty well, I was very pleased.
Car went a peak mph of 167.66, having to pedal in first gear. I saw 16 psi on that run.
I made it to the third round of king of the streets, beat up on some expensive iron.
Check out http://www.texasspeedsyndicate.com for more info. 1320 video was there and I'm sure will have VERY nice media.
#516
Car: 1990 formula
The white GTR in the second pic was a Boost Logic 1300 package car. I heard he was more than a little upset when he got beat by a third gen firebird.
I also beat a gen 4 viper with a novi 200 and bottle, a C5 with a YSi, stroker, and bottle, and a suppsed 1500 whp 911 porsche, but I think he was having problems.
#517
Car: 1990 formula
Yes, I drove it to and from the airfield both saturday and sunday, 30 miles each way. Saturday I drove home in the rain with the AC blowing cold!
#520
I love this build
#522
Car: 1990 formula
I'm not sure there are so many rules per se, it's an invitation based event, though you can apply to participate. There is one day of grudge matches that the participants set up themselves, and this fall there were 3 events on sunday. A corvette shootout, a king of the street shootout (anything goes more or less) and a 6 speed shootout. I believe (but can't speak for them) that the persons making the decisions on who attends try to pick high horsepower modified cars that fit the spirit of a street car.
AND, if you had any doubts, I'd say that a car that can drive 30 miles in the rain, on unpaved roads, with the AC and stereo on, running on pump fuel is a street car.
#523
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Very impressive build and results. This was basically the first actual event on this build, correct?
#524
Car: 1990 formula
You are correct. The car has seen one aborted dyno session which was pretty useless, quite a few street miles, some street tuning and a handful of fairly short highway pulls before this event.
I was starting with a baby tuneup that hooked on the street, and making incremental changes to sneak up on the tuneup and get some seat time... I DID drive an outlaw 10.5 car, but the last pass I made in it was almost 4 years ago now. Thankfully the car seems pretty solid and the driving is coming back fast.
#527
Car: 1990 formula
First round of kots. My race is about halfway through.
#528
First round of kots. My race is about halfway through. http://youtu.be/HPuDSPn8EAI
Looks like you start around 3:54
#530
Watching it again damn #6 corvette 189
#533
Car: 1990 formula
Yep, I'm sad about it. I don't like hood pins.
#534
Engine: 383 SBC
Maybe you could go with the hood pin locks instead.
Something like this: http://www.summitracing.com/parts/MRG-1472/
Color match them to the paint and they would blend in.
#536
Car: 1990 formula
Thanks for the tips guys... I like those on summit, and I'll have to look into the C3/C4 stuff.
I found these just browsing around: http://www.turnermotorsport.com/p-18...hood-pins.aspx
and these: http://www.quik-latch.com
#538
i found a video of just ur race against the gt-r
check out the comments
#541
Car: 1990 formula
Round 2 kots. Racing a 1400whp 911 but I think he had issues. Same tune as round 1 but a later start so mph is down a bit.
#542
http://youtu.be/sIEWXaPZmaU
2:39 and Andrew comes out of the gate hard
#544
1 Post
Car: 1989 Camaro RS/ 1992 Camaro z28
Engine: 383 Stroker/ ls3 e-rod
Transmission: borge warner t-56/ tremech t-56
Axle/Gears: 10 bolt, 3.55/ dayna 44(viper) 3.07
You stole my nitto envos! Lol
#545
did you use the eastwood fender roller, to do the rear?
doing mine to get a bit more room, got to love the look of that size of tire.
i could only go with 29.5 Tall(ground FX). but did get the same width.
buying to tool outright,$260.
only to use it one time..lol (who knows)
#546
Car: 1990 formula
That is what I used. I rented it from a local guy.
#548
1 Post
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Very cool car Andrew! You did a fantastic job with it. I'm looking forward to some more vids and track times
#549
Car: 1990 formula
#550
I seem to be having an issue that maybe blowout at 15 psi but i am gapped at .026-.028 i believe. Used to run .030 in old setup to 18 psi no issue under 6000 but never went above that. Now at 6-6.2k i have a limiter action goin on that may be spark blowout. Only does it on higher boost levels not on base boost of 6 psi
