Steering clearance mods / Chain Steering
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Oh I know a whole bunch of folks will find all kinds of fault but I ran into this on a rat rod board and find it to be a great idea on how to deal with engine fitment and the steering shaft, instead of your limiting factory be what fits and doesn't interfere with that, you could ignore all.
Put in the engine where you want it, the header n exhaust you want, put the steering wheel anywhere you want for comfort and only need to make sure and have a bit of firewall room.
Cause it can't be any worse then when ya seen someone has 2-3 joints and several supports to zig-zag the stock rod around some headers.
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: Steering clearance mods / Chain Steering
Yeah and alot of those guys run old drum brakes and no seat belts. Just because a hot rodder does something doesn't make it smart.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Good idea for a farm idea. Bad idea for a street driven vehicle. Might look good at a car show but I wouldn't want to rely on it for steering.
The "2-3 joints and several supports" is far better and safer.
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
FWD trans axles use a chain to pull, not too far off that. Get a quality dust cover, fill it with grease and that should be fine. Assuming you use quality chain
Not sure how that design would work on a 3rd gen though
Transmission: World Class T-5
Axle/Gears: BW 3.45
I saw that on HOT ROD TV. That was done by a pretty well respected hot rod shop.
Car: '91 TA vert
Engine: turboLSx
As well as all the transfer cases using chains to drive the front axles of 4x4 trucks...
It's far from optimum but its kind of cool.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those are backlash-free applications again. Chains have their places, I'm just not sure that in the middle of a responsive steering system is one of them.
Axle/Gears: BW 3.45
As it was explained on the show, that hot rod has a WW2 aircraft theme to it. They wanted to do away with the steering column and use something similar to a WW2 bomber control wheel.
If someone can find some more pics, you'll see what I mean.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Why not just use hydraulic steering?
Danfoss boxes will steer even if the motor stalls and it has no pressure.
BTW, on cars that have two steering wheels (i.e, instructor cars) they are linked together via a chain.
-- Joe
-- Joe
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
If anyone is interested in more info on the hydraulic steering, heres an in depth read on Pirate4x4:
http://www.pirate4x4.com/tech/billav...ng/index3.html
http://www.pirate4x4.com/tech/billav...ng/index2.html
I must admit though, the lack of a steering shaft may raise a few eyebrows for vehicle safety inspections.
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
atleast its two chains one breaks he has time to soil his pants before he pull over
bubbaz28
09-18-2015 02:09 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
