Firstfirebird's first merge collector
Always wanted to make some, these won't end up on the thirdgen, they will go on my e30, but would like to share, very pleased with the results
16ga two 1.75" to single 1.87" stainless. 1.623" slip fits inside the primary side.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Firstfirebird's first merge collector
The 2 into 1 looks relatively easy. A 4 into 1 must be a nightmare.
makig them out of stainless is even more of a bitch then mild steel
Having a band saw makes it "not so bad". Use a block to make the desired angle, then run the bend through. 90 degrees make s a 2-1, 60 degrees makes a 3-1, and double 90 degree cuts make a 4-1.
Typically I buy the best swedged collectors I can find, but am doing something a little different for the experience. I'm making "180 degree" headers for an inline 6. Can't be really 180* since the firing order is 60* apart, but I am using the TDC pairing cyls - so instead of having double 3-1's, it will be a 6-3-1 design.
Worst part about stainless is the blade wear on the saw
If anyone decides to get into headers, I recommend these: http://www.jegs.com/p/Hooker-Headers...63776/10002/-1
Should keep the inside of your headers nice and smooth for airflow.
Mathius
Mathius
Car: 87 GTA
Mathius
Mathius
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
They would create a small step yes, but the assembly time for the headers would drop quite a bit. Probably less leaks to fix and easier to clean up the welds as well.
I usually use magnets to keep the tubes aligned, i'll have to look into these for the next set. thanks Mathius!
Those steps ought to be a lot smaller than the ridge created by a properly penetrated butt weld, and the rings give you the added benefit of not having to be skilled enough to do a proper 100% butt weld, because you've effectively created a lap joint for yourself.
Mathius
Mathius
At $24 each, I'll stick with my butt welds! That's as much as I pay for stainless 180* u-bends.
With a TIG welder and proper penetration, the inside of the weld looks exactly like the outside. I have cut many welded tubes apart to make sure the welds are good.
For keeping the tubes aligned (much better investment since they are re-usable) just ordered a set of 3...
http://www.vansantent.com/welding_ac...ice_clamps.htm
Car: 87 GTA
Now just stack those 2 Y's......Merge the outlets the same way & you've got a really short 4-2-1.
Uh, actually, they're only $1.20 each. You get 20 sleeves for $24.
<shrug> Nothing wrong with doing it on the cheap, but those are an easy way to get a pretty smooth exhaust flow.
There's nothing magical about a TIG welder. A good welder can get the same results with any process as long as the machine will give him the right heat output. As a welder for a living and someone whose been welding for almost 10 years, nothing pisses me off more than to hear someone try to act like a TIG welder gives a superior weld.
That's correct, however there are certified welders who can't get a proper buttweld down, let alone on 16 gauge pipe, and a good weld should be slightly convex and therefore by nature is going to be a lot less smooth than the slight step those rings are going to give it.
So spending $90 on a set of clamps is cheaper than spending $24 for a set of rings? No wonder you couldn't figure out they were only $1.20 apiece. Your math sucks.
Anyways, those clamps will probably technically work, but they're going to be a PITA to position properly and tighten down at the same time. They're also going to take up more room which means if you're mocking up a set of headers in a tight engine bay you might not even have the clearance to use them. The alignment rings take up no more room than the pipe itself, and you can just tack them in place and go.
Your method will work, but trying to pretend its cheaper or easier is absurd, nor do I think it will give better flow no matter how good your welds are.
Mathius
With a TIG welder
Mathius
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I tried those rings on the last set of headers I built. To me they were more trouble than they were worth. While I agree that a properly setup mig welder works fine in alot of situations, I would never build headers with one. In that instance a tig welder is the right tool for the job.
jmo.
Kory
jmo.
Kory
As far as 16ga... 16 or 18ga exhaust is _much_ harder to weld well then what a lot of welders do day in, day out for a living. I'd much rather weld >1/8" thick steel even with too small a welder then I would <14ga with any welder... though I can do both OK.
All that said, I almost always do the 'hold and tack' deal, and if in doubt I'll only put one tack so I can move things around a little and get it just right.
Thanks mark.
I have no problem welding, and you are one of the two guys that helped me a lot when I was learning a few yrs ago. Thanks for all the tips (if you remember even posing in threads with me haha).
TIG welds are fine, I have only been welding for 4yrs as my 2nd job...
Tried getting a good shot of the inside, but whatever, it;' for the same car. I'm not perfect, but am having fun Our 2.5l 6cyl went 12.3@117 with circle track tires. Big fun from small engines.
Still haven't had time to get back on these, but curious to see how the 3-1's turn out.
jmo.
Kory
jmo.
Kory
I'm not sure that I agree about the step, but I haven't seen a set of those rings in person yet, if the inside ring fits very well and has a bit of a chamfer to it it could be, I'd be really surprised if it did though since there is enough variation from tube to tube that even that would create a step bigger than you'd get with even a decent weld done with the crudest stick welder.
Mathius
Was working on 660 headers, sneaked on of my collectors in while at the welding desk
and got the materials in to make the 3-1 and secondaries...
Well, I got the collector tacked and couldn't wait to show it. Stupid 10hrs engineering this stupid thing, I'll let the pics do the talking. Have to weld it solid, trim both ends and weld the expansion pipe on, but whatever, $280 saved on Burns in favor of 10hrs, ftl, but now I know how to make them FTMFW!...
Double vision....
Attachment 403402
Attachment 403403
From the insides, still have a littl more die grinding to do to clean up the tight areas that were difficult to weld...
Attachment 403404
Attachment 403402
Attachment 403403
Attachment 403404
blackz281le
01-11-2016 07:51 AM
no green
01-09-2016 09:22 PM
redformula88
10-14-2015 06:08 PM
