Firebird Dual Intake from Camaros.
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Is there a way to install the dual filter intake that came on the camaros ? Firebirds got a whole piece were the hood sits while camaros came with the same thing but with two square holes ready for the filter, are these pieces interchangeable ? I mean can i just simply bolt one from a camaro to my firebird , i have check and its holded by some bolts i dont see it welded to the car.
Car: 87 GTA
Re: Firebird Dual Intake from Camaros.
Nope & for 2 reasons.....
#1. Not even room between the radiator wall & the hood.
#2. That metal plate locates & supports the hood latch.
You could use hood pins to bypass reason #2, but there still is the hood to radiator wall issue.
I know all this, because I got tired of people saying it wouldn't work, yet had never tried it or could explain why not. So I tried it myself.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
exactly, the issue is that the firebird hoods slope down more to towards the nose that nte camaros, there is not enough room over the radiator core support for the air scoop. Im sure something could be done, but it would involve cutting the top of the core support out and re-fabbing the sheetmetal around the scoops.
the other option, (not really an option because you will NEVER find it), is the dual intake setup from the firehawks with the t-ram manifold. But like i said, you will never find one, and if you happen to, it will cost a fortune,
Engine: 305 TBI L03
Engine: 305 TBI L03
what im thinking now of doing is getting one of those elbows they sell at ebay for tbi trucks and run a tube down to the drivers side were the black canister is , open a hole about 3.5 inches and drop a cone there.
Now speaking about the canister , what can i do with this , do i need it ?? is there any way of eliminationg this item off my car without making any dmg , i have heard some ppl just unplug the rubber hose coming from the steal lines that run to the fuel tank and just dumb the hose to the side of their fender , can this be done ? If it cant them im just going to same and buy a functional ramn air hood that sits were my filter element is.
i think it can be made to work, see iff you can find a air intake setup from a pre85 5.0HO carbed motor (l69). It had a dual snorkel setup, like you stock one, but with a intake on both sides. Im sure it can be made to work.
that canister collects fuel vapor from the fuel tank and absorbs them, i would leave it alone if you can.
Engine: 305 TBI L03
Car: 1991 RS
Engine: 5.0
Have you looked into an Airraid cold air intake for an s10 or silverado? Probably your best bet. Or at least give you an idea of something that might work. Another option would be a cowl hood with a K&N extreme lid. But thats a little more expensive.
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
maybe an oddball idea since i haven't looked at one in several years... but what about flipping the camaro intake upside down and making it seal up to the front vents in a GTA hood when it's closed?
Car: 1991 RS
Engine: 5.0
It sounds good. But the problem is that the vents on a TA hood are too close together for a TPI air intake. (that is what you were referring to right?) Plus there is still a problem of the hood being too low.
so whats your beef there mr. interweb tough guy?
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
i imagine having the filter in the fender is going PROBALY be your best bet, but instead of dealing with the carcoal canister, its probaly an better idea to relocate the battery in the trunk and do it at that fender. This way your getting MUCH cooler air (your open element is KILLING you!) and your helping weight distribution.
same problem and still wont work. The TA vents are still forward of the radiator support.
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
