Rods by Troy Project Camaro- Bad A$$
Car: Stock 1991 B4C Camaro
Engine: 5.7 TPI
Axle/Gears: Stock 2.73
Saw this today at Good Guys show and wanted to share. Its the latest project from Rad rods by Troy T. It looks like we will see it in all the mags next summer.
Engine: 5.7 TPI
Re: Rods by Troy Project Camaro- Bad A$$
Few more picks. Camaro by Troy Trepanier. http://www.radrides.com/ 1987 Camarohttp://www.radrides.com/proj.htm
Still, it's been a long time since I've bothered to check if the gallery was updated. There's a lot of stuff I haven't seen yet like that front end. There's also a lot of stuff I don't understand about that car. I wish they had included some documentation, but I'm sure he's hoping for some discovery channel special or something.
It appears like they had something in mind when they started but then changed their mind as the project wore on. For example, why start with a t-top car, sandblast the top and then cut it out and go with a full roof skin? A guy like Trepanier has unlimited funds to find a straight hard top Camaro to start with. Then they went and mocked up the front end using the stock fascia, with cardboard taped to it, but then went in a different direction for the final design.
Also, what is the deal with the pic I've attached?
It's a shot of the floor pan, but what is the purpose of the channels inside the rockers? Is that where the frame ran? I didn't even bother to check if they went full frame or with subconnectors. Judging by the piecemeal frame horns they added to the front, I'm guessing some hybrid with a frame of types welded directly to the body.
Was there a reason they took the time to tape off the rear wheel wells in cardboard before making the sheet metal part? Maybe to provide rigidness to the pattern?
And why did they take the time to spray paint the cardboard mockup of the front end silver? Was there a reason for this or did they just want it to look nicer for the pics?
In some of those pics it looks like they held their cardboard mockup on with cleco's. There are wrinkles in some of the shots that don't appear to be metal.
There's a ton of great work done to that car. They have some amazing metal shaping talent, but they also have access to very expensive machines I will never be able to afford. Still, I learned a few things and got a few ideas.
But no matter how fancy and well done that thing is, I would cry the first time I bumped the curb with that steel front bumper.
Mathius
Mathius
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Mathius, it's a full frame car with the frame rails running down each rocker panel. The sheetmetal floor inside is just draped over it. I'd expect that the silver spraypaint was to better visualize how it looks in real life and tweak the design before fabricating steel panels.
If it's a full frame car like JeremyNYR pointed out, then it's presumable that they had to do that to cover the frame rail. If you look up by the foot boards it seems to follow the contour of a frame, so that makes sense. The round thing near the center is quite possibly a body mount.
Mathius
Car: 87 GTA
There is already a very long tread going started back in Aug. '09, regarding this car. There was really no need to start a whole new thread about it.
https://www.thirdgen.org/forums/auto...-building.html
Mathius
1 Post
Car: 1984 Trans Am
The foot room looks to be really tight due to the engine appearing to be set further back than stock. I wonder if they're going to move the steering wheel, pedals and seat further back than original also.
Mathius
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
seen this before .. but good thing you re posted . i was looking for this website a while back . couldnt find it. sick ride. something different. any ideas what engine they are building for it?
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
looks like whatever motor they are putting in it, they are planning on putting a couple snails on it.. you can see them in a couple pics..
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Call me crazy but i really don't like it. lots of quality work there for sure but not to crazy about the reshaping of the body.
Car: 84 Camaro
Engine: 350 Goodwrench with Edelbrock pkg
Transmission: rebuilt 700R4
yeah not too fond of most of the body, i do like the 5th Gen tail lights, im working on fabricating mounts for an early 2nd Gen Camaro tail light set up, at first i thought these guys beat me to it and i yelled "those diabolical sons of b****es!" but yeah its a nice new take on an old body.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
This car is shaping up nicely...
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Excellent fabrication - ugly car.
Car: 85 Z28
Engine: 327
Yeah it looks really cheesy. Might as well do what that guy Leepoo does and just start with some random car. Skilled fabrucation, but not good looking.
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Car looks awesome! i love the the 5th gen tailights they look better in the 3rd gen then they do in a 5th gen. He does some A1 work over their, i think i saw some twin turbos somewhere in the albums on his website, which by the way took me like three days to get through. LOL.
I hate the car, over-all, but do like the work done to the sides and taillight areas. I think the thing that takes it over the top are the "bullets" (For lack of a better term) on the front and rear corner and also the spoiler. Love the front fenders and door skins.
it probably won't see any street time, it'll probably sit in a garage, and not move, except for the occasional car show, which it'll be trailered to I'm sure.
Car: 85 z28
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Mathius
I know this is an old post and I'm not an expert but I think the extra rails by the rockers are where the exhaust pipes will go. If you look at the floor plan there is no other place to put the pipes.
Weird though,, wouldn't that make the floor and interior really hot if you drove it more that two miles?
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
love the 5th gen style, looks great
1 Post
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Thanks for posting those pics! I haven't looked at the gallery of that car being built in quite some time. Makes me wonder how many hours of work have been put into that car so far!
Car: 1992 camaro rs
Engine: 305ci v8
Axle/Gears: stock
ZOMG! I want the rear end on this thing! Where can I get that bumper/tail light kit.
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
THIS IS ONE BAAD MARO! the 5th gen tail lights did it for me love the custom body work. sicckkkk third gen!
ambainb
04-25-2016 09:21 PM
gixxer92
09-01-2015 04:32 PM
BlackphantomZ28
08-22-2015 01:00 PM
