Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Link to Info on Lexan Rear Glass Install?
Old 04-29-2010 | 05:14 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Does anybody have a link or info on installing the lexan rear hatch glass? I searched and found nothing....but I remembered a guy on cardomain.com that had his entire install documented. Does anybody know?
Old 04-29-2010 | 07:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Link to Info on Lexan Rear Glass Install?
Never seen it. You would need some sort of framework to hold the Lexan in place and for some way to attach the deck lid, lift struts etc.
My Lexan rear window is a race only fabrication. The Lexan is riveted to the body skin and the decklid is a piece of aluminum attached with Dzus fasteners in case I need to access the battery. The Lexan is permanently attached and doesn't open. There are 2 supports running along the rear cage tubes to help hold the Lexan up.
Percy's may have a complete kit available but it won't be cheap. Using Lexan for any window is not street legal.
http://www.percyshp.com/
Old 04-30-2010 | 09:13 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Bluelightning on cardomain......
http://www.cardomain.com/ride/403007/9
The hatch looks great in the pics.
1992rs/ss
05-19-2020 07:02 PM
Vintageracer
01-10-2020 05:33 PM
1992rs/ss
16
01-28-2016 09:58 PM
AkDrifted
08-17-2015 07:45 PM
BrianI
08-09-2015 11:52 AM
Quick Reply: Link to Info on Lexan Rear Glass Install?
