fabbing in ttops
Car: 1990 camaro rs 3.1 v6
Engine: 3.1 v6
fabbing in ttops
i have a 1990 camaro with a regular solid roof and im thinking about cutting it and putting in ttops how would this be done and if anyone has pics or if there is thread on it i cant find it but thanks in advance
Car: 87 GTA
Transmission: soon to be t56
Axle/Gears: 3.73 posi
Re: fabbing in ttops
Ive seen this done on other cars to swap in moon roofs. Some turn out nice, most doing. What you have to do is find a ttop car, cut out the roof around the ttop stuff (easiest to do almost the entire roof) then cut yours out swap and weld. If you're patient and meticulous no one will be able to tell the difference
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
anything is possible with deep enough pockets . you could more than likely buy 2 T top 3rd gens for the cost of properly converting your's . my thoughts are to shop for a T top car & trade/sell yours . i have had a couple of both . on a warm clear summer day , nothing like a T top car . on a cold rainy fall day , nothing like a T top car ( not good ) . just my thoughts , what ever you decide good luck .
1 Post
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
here's one thread i found, (not the way I would do it or use it as a guide) but here it is
https://www.thirdgen.org/forums/body...ack-widow.html
Car: 87 GTA
One member her swapped his hardtop to T-top, then swapped it again into a convertible.
Grind the factory paint down to reveal the factory seams, then make your cuts by splitting open the factory stuff, then make your transplants at those points
Obviously this won't work if you use an aftermarket T-top bcar, but gives you a good starting point to do it successfully.
Engine: 3.1 v6
thanks guys i was just thinking about doing this i was trying to find out how much work it would be and for what it would cost or how many hours it would take me to do it i will just stay with the hard top. the camaro is a DD and i have heard that the ttops could cause integrity issues in the right circumstances. thanks for the info
1 Post
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
I can't seem to find the thread but there was a member who did this. He basically took the whole roof from the t-top and transplanted it over removing everything from the spot welds and seems so it went back together like factory.
Car: 87 GTA
I found them, just had to look through my Bookmarks......
https://www.thirdgen.org/forums/body...-top-roof.html
And a Hardtop -> T-top -> Convertible -> Parts car
http://www.cecoatings.com/images/CarStuff/92Z/Targatop/
tmork454
09-29-2015 06:33 PM
Mongoose462ci
09-16-2015 11:46 PM
