Anyone ever do hydrostatic steering?
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
This is for an off-road application, but I was curious if any members have played with it?
-- Joe
-- Joe
Re: Anyone ever do hydrostatic steering?
You have manual steering, then power assist for steering, and hydrostatic is the next step.
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
now im confused are you talking about a hydraulic steering or hydrostatic. or hydraulic assist.
It is used on 4x4s, tractors, front end loaders, and a bunch of other types of machines. Recently I started reading on it to retrofit my front end loader, and I couldn't help but think it could be useful on a car application as well. The danfoss hydraulic steering 'box' could be mounted to the firewall, a normal GM P pump can be used, along with two steering rams and a draglink, or better yet twin cylinder.
The units turn into manual steering should the motor stall and pressure is lost, which would safely steer the car to a stop in the event the car dies.
The only thing that would be of concern is if a hydraulic line blew..
-- Joe
Hydrostatic is what I'm talking about.
-- Joe
-- Joe
Plus, different style boxes work differently. I have a Danfoss OSPM box, which is supposed to provide feedback from opposing forces on the steering cylinders.
Rack and pinion does offer a lot of road feel, but also often makes driving the car feel like a go cart. I had a c4 corvette with performance suspension/steering and I hated the thing. Coupled with 275/40/zr17 tires, it just wasn't fun to drive on anything other than perhaps the best road-race course.
In comparison, the last ws6 thirdgen I owned had a wonderful compromise between performance sporty handling and reasonable daily driver characteristics.
Even my sisters 4th gen I built a few years ago, the rack and pinion is a bit much on anything but the smoothest road. We live in hillbilly country here
-- Joe
Get on coloradok5.com or pirate4x4.com and search their boards for hydro streering. Tons of info between thoes two sites.
The problems with it are: 1 it's illegal in most states, the road feel is usually lost (can be regained with the correct control valve), the numbers of turns required lock to lock is changed (again, juggling parts can change this), plus the steering speed can change. Some people have reported that because of the crown on most roads, you constantly have to be turning the wheel to the left to compensate. A full revolution of the steering wheel would be expected on long straight distances.
The biggest downside to full hydro on the street (in a car or truck) is if you loose a line, you loose all steering. With a mechanical system you still have control.
I've seen a few joystick prototypes over the years from high end car makers. Probably a matter of time.
-- Joe
sjorgens
10-01-2015 07:54 PM
