custom transmission crossmember?
Car: 1988 GTA Trans Am
Engine: HSR 350
im buying long tube headers and i have the 700r4, the problem is once installed the exhaust would have to go under the transmission crossmember. they dont have any after market crossmembers to fix this problem so i was wonder if its possible to cut the crossmember and weld some thick metal strap in a u shape so the pipes go straight back. would it still have good enough strength for all the torque?
Car: 1986 iroc-z
Engine: lt1 intake 406
Axle/Gears: stock 89 gta 10 bolt 3.42 non posi
Re: custom transmission crossmember?
your best bet would probaly be to use a peice of pipe cut in half and weld that to the crossmember
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There have been posts showing pictures of fabricated tranny crossmembers including ones that loop over exhaust pipes. The floor of a third gen is terrible for a simple crossmember design. It's not a simple "tube from side to side" type of design.
The crossmember is holding up a lot of weight. Just don't make a flimsy design.
Engine: HSR 350
Do you know where those posts are exactly that would help alot, or do you have any suggestions on to what could be a better design because i have only seen the ones where they do it in the U shape with 3/4 inch pieces of metal. have you seen any other designs other than that one??
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
https://www.thirdgen.org/forums/exha...orque-arm.html
Will make a nicer one now that I'm swapping in a 4L80E.
Had to edit linked to the wrong crossmemeber
Engine: HSR 350
so then is there a crossmember that is already made for what i want to do? cuz i have asked different techs from different places n they all say that they dont kno of any places that i could just buy one.
Hotrodboba400
12-10-2019 07:07 PM
84 TA NV
09-06-2015 08:02 PM
