bolt in chute mount
Car: 89 camaro rs
Engine: intercooled f1r procharged 383
Transmission: turbo 400
bolt in chute mount
well got no help in the suspension section, try here!!! does anyone know of or make a bolt in chute mount for our cars??? i know wolfe racecraft does for the 4th gen but not sure if it will fit our cars. thanks!!!!
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
Re: bolt in chute mount
You're going to have to make your own. Greezemonkey made one...check it out https://www.thirdgen.org/forums/fabr...g-spoiler.html
I made one similar, but haven't added the stand off for the chute mount or drilled the hole through the bumper. Rather than cut and bend the tube like greeze did, i made two stand offs and ran the long bar across them. If you want, I can try to take some pictures of it, but I would have to do some disassembly of my car. Just let me know.
Car: 89 camaro rs
id really appreciate it if it isnt too much trouble. i want mine to be able to keep the plate, and remove the chute and all. sounds like what you have done. does yours have a y at the end? one part for the chute stray and another for the chute pack to go into??? if so i can uses the rear part on the other pics for my mount
Car: 89 camaro rs
on my buddy's vega it had a tube with the strap mount, and the chite mount above it. and it all came off the car in 1 piece.
Car: '82 Z-28
Engine: 355
badbilly, I'll see what I can come up with today after work. It's been raining it's a$$ off here and the car is outside.
Car: 89 camaro rs
if it is a pain, ill go with greezemonkey's design. is the rear bumper a pain to get off the car???
Car: '82 Z-28
Engine: 355
The plates are 6.5" (across the top) and 6" across the bottom. The standoffs are 5" to the short side of the notch. When my car needs a chute, all I'll have to do it drill the hole in the bumper cover and add the portion for the chute mount. If you have any more questions, just let me know.
Car: 89 camaro rs
no that is great!!!!!! i think ill be tackling it this weekend!!!!!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They really need to get back to making cars where you don't need to strip the car down just to change a light bulb. Third gens are terrible if you need to change a taillight bulb.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
A friend of mine bought a bolt on trailer hitch and use that to mount the chute. It was a complete bolt on besides the welding the chute mount on the receiver.
Car: 89 camaro rs
ok themore i get into this the more anwsers i need!!!! what did you guys do to attach the bottom of the bumper cover since the holes for the plastic clips arent there now. was thinking of some aluminum straps or something.
Car: 87 IROC L98
Mine is only there for cosmetics. You can't push my car from the front or rear bumpers since there's nothing behind the plastic covers any more.
If you're really concerned about it, a small tubular structure can be fabricated but still won't offer any strength if the bumper is pushed.
Car: 89 camaro rs
im just concerned with it floppin around, want it to be a clear and neat install. but if that is how everyone does it, i will too
Terrell351
06-13-2021 01:13 PM
ambainb
04-25-2016 09:21 PM
