Custom aluminum gas tanks
1 Post
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Anyone running a custom aluminum gas tank? I am looking at getting one made and just wanted to see some pics and get some thoughts/suggestion on what I should try and get made to get a better tank than stock.
As of right now I am looking at getting a tank made with a sump with AN fittings welded in for the fuel supply and return line. Not sure what to do about the fuel sender yet. I also want to get either plates installed or some sort of mounting brackets for the aeromotive fuel pump and filters.
Please post pics if you got.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Custom aluminum gas tanks
Nasty Performance makes one. Its technically for a 4th gen, but it will fit, you need the 4th gen filler assembly.
It fits ok, the 3rd gen tank straps are short though. It uses a tube style sending unit, has 2-1/2 FNPT outlets in the sump, a 3/8" FNPT return and 1/4"FNPT vent. It doesn't play nice with you exhaust or heat shields, you will have to modifty things a bit.
The only complaint i have is they apparently dont baffle the vent connection. So fuel can slosh out unless you get creative.
there are mounting provisions on the driverside for a fule pump, but i dont know which pump is sopposed to fit there. I though the a1000, but no.
Car: 87 GTA
https://www.thirdgen.org/forums/body...one-phase.html
1 Post
Car: 1992 z28
thanks guys. I will take a look at neils' tank
Car: 86 Trans am
Engine: workin on a 383 for it!
depends what do you want to run it in?
because I am also wanting to well I want to make one for mine but am trying to figure out the same things
AkDrifted
08-17-2015 07:45 PM
