Steel upper radiator support
1 Post
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
im looking to make a upper radiator support out of steel to replace the stock plastic support. It is really flimsy because i cut the lower half of it off where it bolted to the stock fan. i cut it because i swapped a set of 4th gen fans onto the radiator and it got in the way. it works for now but i dont like how flimsy it is. i've seen pics of metal supports and i cant find them anywhere so im going to try yo make one.
any ideas are welcome.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Steel upper radiator support
no bolt on replacement exsists, you do have to make your own. Its not hard, though i would use stainless or aluminum.
Have to find somebody with a break to make a couple bends, then cut to size and drill the mounting holes
Car: 1986 IROC-Z
Engine: 420HP ZZ4 350
Transmission: TH350
Axle/Gears: 4:11's
thats how mine is. Had a peice cut out of aluminum and had the end bent to go under the radiator. here is a couple of pics of it to give you a idea.
1 Post
wow that looks good, i guess im gonna start making mine soon.
looks like i'll be cutting up some old speed limit signs i have and polish them up lol.
thanks guys
thanks guys
1 Post
heres what i came up with
I am going to sand it down and re-paint it. (paint came out shitty)
but it did do what I wanted it to do.
sorry if the pics are too big
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
that looks good. Here is the one I made. It's made of steel. I plan on either chroming or painting it.
1 Post
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
mine, came with the car. it has a griffin radiator so it might be a griffin part. has the k&n stop sign on it in the middle if you're wondering
Member JerryWho made a nice aluminum one up for me. The pictures are in this thread.
https://www.thirdgen.org/forums/cool...tallation.html
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
[quote=red406;4321771]that looks good. Here is the one I made. It's made of steel. I plan on either chroming or painting it.
Did you make or have another one of these metal radiator supports?
1 Post
I guess it wouldn't be a bad idea if someone started making these to sell them.
